FMU Disks? which is which
How do i know which disk to use? Which one is 12:1, 10:1, 6:1 and etc? which combination? PLEASE HELP!!! What i really want to know is which one is the 12:1 disk! Thanks guys
[Modified by B20Zturbo, 12:43 AM 7/15/2002]
It depends on what size injectors you will be running. If you are using stock injectors go with the 12:1 fmu. The bigger your injectors you use, the smaller fmu you need to use. ex. 310cc with 8:1 or 10:1
I'm asking which disk is which? if you look at the picture, if you can't see it please look at the link below and then click at the bottom most picture.!!! Thanks guys
oops, thanks man!
Do i just install the biggest disk? What about the rings? So in order to use the 12:1 i just put in the largest rings and disk together? that's all i need to know!
[Modified by B20Zturbo, 8:52 PM 7/14/2002]
Do i just install the biggest disk? What about the rings? So in order to use the 12:1 i just put in the largest rings and disk together? that's all i need to know![Modified by B20Zturbo, 8:52 PM 7/14/2002]
