94 K20a2 EG Hatch
I've decided to try to sell my freshly done K swapped EG hatch because I have another project on the way. This car is done right ladies and gentlemen! My friends and I have put a lot of hard work into this car and money. You will not be disappointed in the quality of work. If you count how many brand new parts are on this car, you can safely say this is practically a brand new car. A little more work and you can easily have one of the cleanest K-swapped EG hatches in the area.
Location - West Michigan
Price - NEW 9,500
There are a couple dents, overspray, and minimal rust. All of these problems are easy to fix. So don't worry and I will get pics if your worried about it.
- It was freshly waxed for the Allspeed BBQ
Brand new OEM BLACK dash (last brand new OEM black EG Dash)
Brand new OEM Black carpet
Brand new OEM black door steps
Brand new Karcepts shifter plate
Brand new paint in the hatch area
Brand new Skunk2 strut brace
Mint EX/SI Cluster
Corbeau 4 Point Harnesses
Clean soldered wiring (not crimped)
- The only reason why I rated my interior lower was because Im missing some interior pieces like console, vents, and radio etc.
Suspension/Brakes/Wheels = 9.5 out of 10
Brand new Skunk2 rear LCA's
Brand new 1" Master Cylinder
Brand new 99 Si calipers
Brand new Brembo rotors
Brand new Skunk2 rear camber kit
Brand new Hawk Performance brake pads
Brand new Misc hardware
Skunk2 Front camber kit
Stainless steel brake lines
Energy suspension bushings all around
Lower rear tie bar
BFG KD 95% tread
Bronze Rota Attacks
- Let me tell ya this car stops on a dime!
K20a2 10k mileage
Wire Tuck
Relocated Proportioning valve
Relocated Fuse Box
Freshly painted engine bay
R Crew header
Kpro Hondata ECU
Golden Eagle fuel rail
Walbro fuel pump
Aeromotive fuel pressure regulator
Aeromotive fuel filter
Hasport mounts
Hasport stage 2 axles
Fluidyne Radiator
Brand new RBC Manifold
Brand new Karcepts cold air intake
Brand new Karcepts TB Adaptor
Brand new NGK Iridium Spark plugs ($50)
Brand new Braile battery = 11.5 lbs
Brand new Hybrid Racing conversion harness
Brand new AN fittings
Brand new Nylon fuel hose
Brand new OEM Knock sensor
Brand new OEM Denso O2 sensor
Brand new Fuel pressure gauge
Always used Mobil 1 oil
- 2nd gear roll spins the tires! Im pretty sure I can get in the 12s 1/4 time. Next week I may have some slips.
K20a Type R Tranny
5.062 Final Drive
Quaife LSD
ACT Clutch
ACT Flywheel
- A lot of life in the tranny setup!
Modified by JaSoNe at 8:04 PM 9/17/2008
Price - NEW 9,500
Mint EX/SI Cluster
Lower rear tie bar
BFG KD 95% tread
Bronze Rota Attacks
K20a2 10k mileage
Wire Tuck
Relocated Fuse Box
R Crew header
Kpro Hondata ECU
Walbro fuel pump
Hasport mounts
Fluidyne Radiator
K20a Type R Tranny
5.062 Final Drive
Quaife LSD
ACT Clutch
ACT Flywheel
