stock d16 240hp @ 221 ft.lbs
fairly simple setup we were at the dyno for an hour we could have smoothened it out , but this is what we have for now. I think it had more in it too, but time for some track time! This is in a 1991 civic dx four door.
stock jdm sohc zc (very similar to d16a6 88-91 si engine)
Mfactory catch can
dsm 450cc injectors
tuner toys 14b feed and return oil line kit
full stainless log manifold
3" downpipe off the turbo sectioned wastegate (reduced turbulence)
K-teller full 3" straight through exhaust with high flow cat
dsm 14b turbo (oil and water cooled)
6061 2.5"aluminum charge piping
4 ply couplers with t-bolt clamps
Turboxs Vport blow off valve
22x9x3 front mount intercooler
jdm zc lsd transmission
Custom euro drive kevalr clutch (sprung full disc capable of over 400 ft.lbs)
poly urthane bushings all around
PIC fully adjustable coilovers 10k and 8k?
autometer sport comp 2 boost/vacuum gauge (30/30)
91 civic si manual cluster
Converted to 5 speed
converted to obd1 (p28 ecu,obd1 non-vtec distributor, obd0 to obd1 conversion harness)
obd1 to obd0 distributor jumper harness (made from spare harnesses)
Walbro 255 lph pump
slim fan on single core 92-95 rad
battery relocation
Maintence:
valve lash adjustment
ngk v-power heat range 7's
throttle body service
decarbonized engine
cleaned iacv
re set idle adjustments
rewired fuel pump
compression tested & leak down
Mfactory catch can
dsm 450cc injectors
Walbro 255 lph pump
battery relocation
Maintence:
decarbonized engine
cleaned iacv
rewired fuel pump
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RubenPrelude »</TD></TR><TR><TD CLASS="quote">How much boost are you running?</TD></TR></TABLE>
sorry i didn't make that clear 11.8 psi and i think i could lower it some and make the same power because i think the timing was still conservative.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver1689 »</TD></TR><TR><TD CLASS="quote">prolly a good amount considering its a 14b turbo, nice budget build setup</TD></TR></TABLE>
thanks, yeah it shaped up to be pretty good my goal was to hit 200 ft.lbs , but we got 198 ft.lbs on the baseline pull after just a street tune. He was driving it for 8 months before we were able to get it on the dyno.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rextec »</TD></TR><TR><TD CLASS="quote">LOVE THE SIMPLE SETUP! godd power looks like a fun powerband. pics of the car????</TD></TR></TABLE>
thanks, yeah i should get pics of the car up of the car soon
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zex_cool »</TD></TR><TR><TD CLASS="quote">why only rev to 6.4K ?
looked like a killer graph until i looked down at the rpm.
It doesn't have a vtec head, however you could probably rev it out to about 7K if it is making power. I rev mine out to 6800.
It's nice to see another sohc zc making some power.
</TD></TR></TABLE>It doesn't have a vtec head, however you could probably rev it out to about 7K if it is making power. I rev mine out to 6800.
i rev'd my y7 to 7-7.2K back in the day. stock is 6.6K i think.
if its like a a6 head, it should have some sturdy springs. 7k aint ****.
i dont see it making more power but it would make for even a broader powerband. either way
looked like a killer graph until i looked down at the rpm. </TD></TR></TABLE>
well the small 14b seems to plateau at about 4500-5000 rpm and the torque seems to be falling off up top. To make the car more relaible we want to keep the revs down but still retain good power band so shifting he won't fall out of it. If he shifts at 6500 rpm he would have to fall below 4250 roughly. I am pretty happy for the tuning portion only being street tuned and then dynoed for an hour. The base pull was 213 hp @ 198 ft. lbs in gernally the same power trend. The goal to begin with was 200 ft.lbs and i was not really concerned for the hp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drew Peacock »</TD></TR><TR><TD CLASS="quote">THe sohc zc's don't really like high rpm in my experience get pretty noisy after 6krpm.
Nice result and the lsd l3 gboxs are rare.</TD></TR></TABLE>
yeah we were lucky enough to get that trans from a dohc zc swap the was in the car before. It really is an awsome transmission in my opinion and thumbs up that its lsd.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by willyboyK20 »</TD></TR><TR><TD CLASS="quote">good setup.
Any plans on ignition upgrades?
Also are you guys running a 3bar map?</TD></TR></TABLE>
yeah we are running a 3 bar because it was given to me for free. No plans for ignition upgrades.
I'm curious why the torque plateaus between 3.3k and 3.8k, too much/too little timing in the lower boost columns? I always try to tune with as little boost as possible, then max, then places in between if I have time.
Aside from that, looks like a good deal of power from a 14b and a stock non-vtec motor.
yeah it does have a very nice powerband, im diggin the torque. didnt notice it was a non-vtec motor, bet that helps contribute to the torque. never understood why but the non-vtec motors typically have high tq numbers on par with hp.
lmao you must of had a bad sohc zc or something. i have a sohc zc and it loves to hit 7200 rpm. and its not noisy
OP: anyway great numbers and simple set-up i love it. glad its non vtec man people swear that the sohc vtec's are the only ones that can make good power. glad your being different.
Modified by 661rex89si at 3:42 AM 5/4/2008
88sleeperx
Aug 21, 2006 08:33 AM
EFbomb
Apr 3, 2006 09:51 AM
