A/C Condenser problem.
Old Apr 29, 2008 | 01:35 PM
slogrnthing's Avatar
Default A/C Condenser problem.
Every time I turn on my A/C the Condenser Fan Fuse blows out right away. I've hooked the fan to a direct 12volt to test if it's a bad fan and it spins freely. I have no idea what's wrong with it. It was working perfectly the other day and now it keeps blowing that fuse..any help would be really appreciated..oh btw the car is a 96 Civic Hatchback DX with a ls/vtec on a chipped p28 ecu.
Old Apr 29, 2008 | 01:43 PM
Former User's Avatar
Default Re: A/C Condenser problem. (slogrnthing)
Check for an electrical short (damaged wire) in the white wire running between the condenser fan relay and the fan itself, as well as the connectors at each end.
Old Apr 29, 2008 | 02:19 PM
Default Re: A/C Condenser problem. (RonJ@HT)
I just check to see if there was any damage in the white wire and the connector ends and they all seem fine. Any other ideas?
Old Apr 29, 2008 | 03:02 PM
help? any ideas are really appreciated..........??
Old Apr 29, 2008 | 04:06 PM
Either the condenser fan relay in the under-hood fuse/relay box is bad, or the under-hood fuse/relay box itself is bad.
mark458
May 3, 2010 08:07 AM
FLCivic
Dec 18, 2007 04:37 PM
lilo_goki
Dec 3, 2007 02:47 PM
Taikonaut
Nov 4, 2005 11:26 AM
Nos4R2
Jan 26, 2003 09:40 PM
