75mm edelbrock throttle body tps question?
I want to purchase the edelbrock throttle body for my setup but was wondering about the tps. I know people said that I have to run a full stand alone if I want to use a mustang throttle body because of the tps calibration not compatible with honda. But the edelbrock throttle body that they sell are for hondas and I want to get it from hybrid performance but want to make sure if it will work with crome or ectune?
i have been running that throttle body for about 6 months. I did absolutely nothing to install it. I went to the junk yard cut a clip off of a mustang thottle body, wired the three wires is. Hooked up hondata and read my sensor readings. They are almost identical to stock. I believe it went down to 5% closed and 98% open, with no adjustments at all. the tps sensor itself is even adjustable. It was a lot easier then i thought it was going to be. Great throttle body by the way. I had to open up my victor x manifold quite a bit to accept this thing. Also you will need that 5.0 bolt pattern to honda pattern adapter that they sell. its 25 bucks let me know if you want a part number
