TW: d16z6 motor with 140k miles
testing water if anyone is interested in a almost complete z6 motor.
Comes with 8.5mm msd spark plug wires, xspower 2.5 exhaust manifold, oem exedy clutch 20k miles, new water pump 20k miles, new timing belt 20k miles, new o2 sensor 10k miles, new ngk r spark plug 7k miles, b&m short shifter, Think thats about it. Motor will come with tranny, longblock, shift linkage, both axles, and rear mount.
Has a leak on the vtec solenoid but I bought a new gasket for it (not installed). change with 5w-30 mobil 1 every 3k miles.
(race once and beat a si coupe)
Modified by sirt_eg at 4:44 PM 6/5/2008
I get 320-400 miles per gallon. I usually get 395 until I refill the tank. From milwaukee all the way to anoka. Small road I get about 290-320 to the tank. I like to conserve my gas so I dont rev or race it. Since the gas price is like 3.50
. come hear it run.
. come hear it run.
$500 and its yours. Motor is out of the car. Will deliver for $520 within the milwaukee area.
Whats missing on this swap is engine harness, obd1 dizzy harness plug, obd1 injectors, ecu, motor mount.
Whats included is obd2 dizzy harness plug, obd2 SI injectors w/harness, longblock, tranny, both axles, shift linkage, short shifter, xspower headers, 8.5mm msd wires, Intake manifold, etc. Practically everything except for the listed above that is not included.
Cause I swap the obd1 parts into my ls/v
Everything works. You can also swap out your old motor parts into it also. I need money to finish my car cause its been sitting out for 2weeks now. motor came out of my 93 civic si.
Modified by sirt_eg at 12:42 PM 6/12/2008
Everything works. You can also swap out your old motor parts into it also. I need money to finish my car cause its been sitting out for 2weeks now. motor came out of my 93 civic si. Modified by sirt_eg at 12:42 PM 6/12/2008
motiondc5
Mid-Atlantic (Sales)
May 31, 2007 02:48 PM
drmaster
Jan 10, 2007 07:26 PM
N1NjA TuRtLE
16
Oct 20, 2002 02:06 AM
