Ls or Z6?
Old Apr 29, 2008 | 08:08 AM
96 EX's Avatar
Default Ls or Z6?
So yesterday I went to the local junk yard for a horn and came across a couple ruff diamonds in the mix. One I found a d16z6 longblock with everything but a valve cover and a cam pulley. Other than that is complete and I also seen a b18b1 out of a 94 LS. The LS is an auto so I was wondering if the motor mounts would still work in a 5speed? But with gas hitting $3.70 a gallon Im a little worried about MPG's. This will be my first build and relatively simple, Im not looking for all out power just something I can take to the road course and have fun with every now and then. Its going in a EJ8 (96 Ex). Any opinions welcome.
Old Apr 29, 2008 | 08:18 AM
bubblebrain's Avatar
Default Re: Ls or Z6? (96 EX)
LS!!! more torque and power for pretty close to the same amount.
Old Apr 29, 2008 | 08:20 AM
96 EX's Avatar
Default Re: Ls or Z6? (bubblebrain)
What about the motor mounts? It is out of an automatic so this is one of my concerns.
Old Apr 29, 2008 | 09:07 AM
prophecy7115's Avatar
I have an ls in my del sol
couldnt be happier. One thigs you HAVE to do is get a b16 tranny or a gsr. The ls tranny really slows you down ALOT.
i get around 25-30 mpg
Old Apr 29, 2008 | 10:07 AM
96 EX's Avatar
Default Re: Ls or Z6? (prophecy7115)
I was planning on a GSR w/ LSD if I chose the LS, an 25-30mpg isnt bad in my opinion. Although no one has answered my question of if the motor mounts out of the automatic will work in my 5speed?? Thanks!
Old Apr 29, 2008 | 10:59 AM
freeagent's Avatar
i to have the same question....
ttt
Old Apr 29, 2008 | 11:07 AM
Dasfinc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 EX &raquo;</TD></TR><TR><TD CLASS="quote">I was planning on a GSR w/ LSD if I chose the LS, an 25-30mpg isnt bad in my opinion. Although no one has answered my question of if the motor mounts out of the automatic will work in my 5speed?? Thanks!
In a 96-00 Platform, I don't believe they will work, and I know for a fact the rear bracket will not as I ran into that problem in my 92 CX *the rear auto 'T-Bracket'* is different for the manual and auto transmissions.
The motor however is the same as the manual one, so when you buy a manual trans, be sure to buy the rear T-bracket off a 99-00 Civic SI, as well as the dust shield for the manual transmission.
Do some searches in the FAQ's for whats needed, the information is already there.
Old Apr 29, 2008 | 11:19 AM
96 EX's Avatar
Default Re: Ls or Z6? (Dasfinc)
Alright thank you sir. I figured they couldnt be used but wanted to make sure before I go pull this beauty out of the teg.
jdmyelloweg
Mar 9, 2009 05:59 PM
mattyfo0z
26
May 14, 2008 10:14 AM
hondachris1994
Mar 22, 2006 10:50 AM
95cxhatch
Nov 24, 2003 03:59 PM
