Need some diagnosis
Old Jul 12, 2002 | 08:41 PM
CivicBoi's Avatar
Default Need some diagnosis
Temp guage is going up when I'm at 120/kmph..(75 mph). Pass the half way point of the guage.. but when i release the gas pedal it starts to go back down.
Will an incorrect connection of spark plug wires cause this?
I just changed the distributor housing.. does that have any bearing on the problem?
What's causing this?
Thanks for the inputs..
[Modified by crxboi, 9:42 PM 7/12/2002]
Old Jul 12, 2002 | 10:20 PM
ShoeGuy#1's Avatar
Default Re: Need some diagnosis (crxboi)
it shouldn't most likely your car will heat up a little under load... i would try purging your cooling system and checking your thermostat...
dizzi
18
Jan 4, 2013 05:23 PM
captaindammit
Aug 12, 2008 11:26 AM
jbscivichb92
Oct 28, 2004 03:06 PM
mr_mbuna
Apr 15, 2003 12:56 PM
mr_mbuna
Apr 15, 2003 03:22 AM
