torque specs
Old Apr 29, 2008 | 04:10 AM
italianhatch92's Avatar
Default torque specs
ok so i am changing my head gasket and need the specs for removing the head bolts and putting them back in. anyone know the sequence and specs? its a d15b8 motor
Old Apr 29, 2008 | 05:04 AM
ballinboosi's Avatar
Default Re: torque specs (italianhatch92)
how many times you gonna post a thread asking the same questions? Let's try this one more time for you.
It doesn't matter what bolt you take out first
then take your head to get checked and shaved
then clean the **** out of your block
make sure you put the gasket on right or you will F it up.
go to a parts store and they can give you the specs and sequence
an if you get new head bolts you have to tighten an loosen them 3 times as they will stretch a little and if you don't you will blow the gasket again (from what I've been told)
Old Apr 29, 2008 | 07:05 AM
ddd4114's Avatar
Default Re: torque specs (ballinboosi)
91CrxMann
25
Jul 10, 2010 01:48 PM
scoob8000
Honda Civic (2001 - 2005)
Jan 5, 2010 07:32 PM
bigizsosexy
Apr 30, 2008 10:38 AM
JDM-JAMES
Mar 20, 2008 07:29 AM
ispteg
Aug 21, 2002 03:16 PM
