rapid clicking sometimes with no start
Old Apr 28, 2008 | 10:06 PM
turkeyslow's Avatar
Default rapid clicking sometimes with no start
hey there,
about 3/4 of the time when i start my car after it sits for more then a few hours the engine wont turn over however my main relay and possibly my starter solenoid make a rapid clicking noise. and after i try this a few times my car eventually starts. any thoughts what my poroblem may be??
thanks in advance
Old Apr 28, 2008 | 10:17 PM
Frickr's Avatar
Default Re: rapid clicking sometimes with no start (turkeyslow)
whats the condition of your battery?
Old Apr 28, 2008 | 10:33 PM
watsvtecEK's Avatar
Default Re: rapid clicking sometimes with no start (Frickr)
^^ Also check battery terminals for corrosion.
Old Apr 29, 2008 | 09:17 AM
turkeyslow's Avatar
terminals look fine, batter holds charge at 12.something volts maybe ill swap em out and see what happens. any other thoughts?
Old Apr 29, 2008 | 09:22 AM
95delsolz6's Avatar
Is your main relay faulty or maybe the connection?
Old Apr 29, 2008 | 09:23 AM
Frickr's Avatar
Default Re: rapid clicking sometimes with no start (95delsolz6)
hows the conection on the starter itself, and also what about the conditions of your grounds?
Old Apr 29, 2008 | 10:00 AM
ballinboosi's Avatar
ya I would check your starter connection, cuz it sounds like your just not getting good power or ground
Old Apr 29, 2008 | 05:48 PM
mikeycivic's Avatar
Default Re: rapid clicking sometimes with no start (ballinboosi)
starter is going bad
Old Apr 29, 2008 | 08:41 PM
turkeyslow's Avatar
you guys have any recommendations for cleaning the grounds, there is a fair amount of corrosion and it definitly has to be more that i cant see.
I once saw something about letting the ground wires soak in bakingsoda/water. anyone try this? work well? any better ideas other then buying new wires?
thanks mangs i appreciate it!
Old Apr 29, 2008 | 09:31 PM
2wheelhunter's Avatar
Default Re: (turkeyslow)
just try replacing the battery
Old Apr 29, 2008 | 09:37 PM
mikeycivic's Avatar
Default Re: (2wheelhunter)
clicking is almost always starter
Old Apr 29, 2008 | 09:43 PM
RS-2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turkeyslow &raquo;</TD></TR><TR><TD CLASS="quote">you guys have any recommendations for cleaning the grounds, there is a fair amount of corrosion and it definitly has to be more that i cant see.
thanks mangs i appreciate it!</TD></TR></TABLE>
it dissengrates almost immediatly with a baking soda/water paste
Old Apr 29, 2008 | 09:44 PM
Default Re: (mikeycivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeycivic &raquo;</TD></TR><TR><TD CLASS="quote">clicking is almost always starter</TD></TR></TABLE>
right and that sounds legit but the OP says it only happens after sitting a while.. that wouldnt effect the starter
Old Apr 29, 2008 | 09:49 PM
mikeycivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2wheelhunter &raquo;</TD></TR><TR><TD CLASS="quote">
right and that sounds legit but the OP says it only happens after sitting a while.. that wouldnt effect the starter</TD></TR></TABLE>
true too, but if it was his battery I think he would hear it attempting to start like if he had a low battery, not a rapid clicking sound. Plus he checked the battery and the volts are ok.
Old Apr 29, 2008 | 10:31 PM
RS-2's Avatar
low batterys have that rapis clicking too
Old Apr 30, 2008 | 12:26 AM
VRD^don's Avatar
Default Re: (RS-2)
check your thermostat ground. that might of gotten loose. and clean all of your other grounds while your at it.
Old Apr 30, 2008 | 09:24 AM
turkeyslow's Avatar
Default Re: (VRD^don)
okay after all of that nonsense. turns out i never torqued that bracket where the tranny ground connects after a clutch job. oops
J9D6M
Dec 18, 2007 10:40 AM
CiViC I2aCeI2
Jun 19, 2006 09:18 AM
Fatboy1985
Dec 26, 2003 02:38 AM
jolt-tsp
Oct 31, 2003 04:17 PM
mingchi69
Jul 14, 2003 06:14 PM
