Injectors?
Old Apr 28, 2008 | 10:02 PM
thepkilla's Avatar
Default Injectors?
Hi, I'm new to these forums. I just wanted to know if I decided to upgrade my stock F22's injectors to 30lb, would I have to do anything to the ECU or FPR?
Thanks,
Josh
Old Apr 29, 2008 | 01:51 AM
GhostAccord's Avatar
Default Re: Injectors? (thepkilla)
Short answer yes to the ECU and No to the FPR.
IMO, Upgrading fuel injectors to 310's without the supporting mods isn't going to gain anything. By supporting mods I am not referring to your everyday bolt-ons such as a CAI, Headers & Exhaust. The stock 240's can handle that level of modification. Add a set of higher compression pistons and a cam to the mix and you would probably need to go up to 310's.
If you do end up getting a set of 310's you will definitely need a tunable ECU. You will have to tune the injector to match your F22's needs.
Old Apr 29, 2008 | 07:24 AM
thepkilla's Avatar
Default Re: Injectors? (GhostAccord)
Thanks for the reply. I have a Megasquirt 1 v3 with spark control that I was going to use for my audi, but we're getting rid of that car. Has anyone here used Megasquirt successfully?
Thanks,
Josh
Tommy22
K Series
Jul 18, 2014 03:29 PM
frostwhite_92
Engine Management and Tuning
Nov 12, 2011 12:33 AM
bigsnorlax
Dec 8, 2009 11:54 AM
Red_Si
Oct 27, 2006 04:05 AM
channy
Jul 24, 2005 08:09 PM
