steering wheel shake?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7panget »</TD></TR><TR><TD CLASS="quote">need some help when im start braking at 40 mph steering wheel shake. i change the rotors and brake already but still shake....pls help ty
Im having the same problem although I havent delved into it yet. I thought mine was probably warped rotors but now Im wondering.
</TD></TR></TABLE>Im having the same problem although I havent delved into it yet. I thought mine was probably warped rotors but now Im wondering.
Tires or unbalanced rim? Probably not though.
You gotta think about it this way... Theres only so many additional systems involved when youre braking versus when youre accelerating... If you get shake while accelerating it could be more things... tires, rims, axles, etc.... if the shake only happens when youre braking it can only be a few things... pads, rotors or POSSIBLY a bad rear engine mount. The one that bolts to the front rear crossmember. But if it was that, youd probably have shake through the wheel at other times, especially at idle.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schueytenten »</TD></TR><TR><TD CLASS="quote">rack end bushing.
X2
also could be tie rod ends i know i have the same problem and i know its my tie rods. also is probably the stablizer bar and bushings
X2
x3
rack end bushings and pinion adjustment.
look in the faqs for the explanation.
x3
baaao
Acura TL, RL & ZDX
11
Nov 13, 2008 02:03 PM
JDM_rolex
18
Oct 7, 2007 08:30 AM
JDM_SOHC
12
Dec 1, 2005 09:33 AM
