MSD RPM activated switch....
ok guys.
i have a MSD RPM activated switch and a realy to activate vtec on my mini me
i wired the switch and the realy , but it doesnt work...
if i ground the relay it works.... but it wont work by rpm's.. the funny part its that when i conect the white cable of the MSD switch to the blue one of the dist... wich its the same one i am using for the tach, it makes my tach stop working.... i cutted the both little wires of the swtich like the instructions said.... but why does my tach stops working when the white cable of the MSD its conected to it ?
does anyone has the conections of these things, so i can make sure i got it right....i am using the MSD rpm switch and a car relay....any help of were to get the wiring instructions will be good.. the instructions of the switch are not good enough. i need help bc i am off next 2 days and i wanna make vtec work..... and help line its not back on until mon 8 am....
thanxs
thanxs
OK, easy fix.
Dont use the tach wire.
Instead, run a wire inside the distributor and take the signal from the [-] side of the coil. Its easy to see which, the coil is clearly marked [-] and [+].
Problem solved
Problem solved
yo dude
THANXS A LOTTTTTTTTTTTTT
just went out. conected it to the (-) side.. went try it and ti ******* worked.......
thanxs a lot again!!!!!!1 u guys here rock!!!!!!
i tried that also when i had the mini me, but i think theres just not enough voltage/amp output from that wire/citcuit so only one will work
i chose the rpm switch over the tach of course
vtec rocks!! i miss it....
No problem man, but if you see the same question in the future be sure to pass along the info
thats why we are all here for....
Tinker219
Sep 17, 2004 04:15 AM
Crxfanatic15
Jan 2, 2003 05:30 AM
