head gasket
Old Apr 28, 2008 | 03:46 PM
ekBlackHatch's Avatar
Default head gasket
Im building my itr motor and i need a Thin head gasket to bump my cr im at 11:3:1 and want around 11:6:1 but cant find a thin gasket for a 82mm bore anyone know of any? I tried searching but no luck only thicker or just oem thickness. any imput would be great ty
Old Apr 29, 2008 | 11:23 AM
Trubluferio's Avatar
Default Re: head gasket (ekBlackHatch)
don't 100 percent quote me on this but my engine builder told me that honda 81mm headgaskets are good up to about 83mm or so. cuz I was askin him for the same reason
Old Apr 29, 2008 | 11:45 AM
98vtec's Avatar
moderator emeritus
just wondering, whats special about 11.6:1 vs 11.3:1?
take the middle layer out or I think spoon makes a thinner gasket.
Old Apr 29, 2008 | 03:10 PM
Default Re: head gasket (98vtec)
because thats the sweet spot for my cams. I was wondering if they can cut it to 82mm? can anyone conferm this. I was going to get the buddy club if I can make it fit a 82mm bore but i asked a few places and said they dont make anything for that. I did however contact someone who can special order a cometic .7mm but how much cr will that raise over stock, stock is .76mm? anyone got any input on this would be great i know some people are running a 82mm bore
Old Apr 29, 2008 | 03:20 PM
onepoint6i's Avatar
all oem head gaskets for 81 MM will work with 82mm pistons/cyl.. i've done it several times...
Old Apr 29, 2008 | 03:27 PM
Default Re: head gasket (onepoint6i)
ok sweet so would any other work the same ie spoon/mugen/bc?
Old Apr 29, 2008 | 07:11 PM
EG6_Axle's Avatar
I believe Cometic can make you a Head Gasket to suit your needs, check with them. . .
Old Apr 29, 2008 | 08:08 PM
Default Re: head gasket (EG6_Axle)
i checked and i could order a custom one and it would be .7mm but thats kinda thick considering stock is .6mm i think. after talking to don i think ill go with a oem and remove the middle or a mugen.
Old Apr 30, 2008 | 08:18 AM
all-mtr-teg's Avatar
PM'ed
Old Apr 30, 2008 | 09:20 PM
Default Re: head gasket (all-mtr-teg)
thanks for the help allmtr. think i got it figured out now. few more parts and she will get assembled
Old Apr 30, 2008 | 09:27 PM
Good luck w/ the build
djstain
Nov 9, 2006 01:41 PM
Ruben19
Apr 27, 2006 08:37 AM
RTW DC2R
Feb 3, 2005 08:41 PM
GreenR
Jul 15, 2002 09:25 PM
schwett
Apr 18, 2002 04:19 PM
