can i bolt on a Vtec head to a B18b1 non vtec
Old Apr 28, 2008 | 12:02 PM
dumbizzle's Avatar
Default can i bolt on a Vtech head to a B18b1 non vtech
would that make a big difference or not really? or can i even do that?
Old Apr 28, 2008 | 12:04 PM
NAmodified's Avatar
Default Re: can i bolt on a Vtech head to a B18b1 non vtech (dumbizzle)
its vtec man. wow. rule 1, search if you have a question, or need to confirm the spelling of something. Go to google and put vtech.
Old Apr 28, 2008 | 12:14 PM
ivan93egreppin210's Avatar
Default Re: can i bolt on a Vtech head to a B18b1 non vtech (NAmodified)
yes you can. its called an lsvtec conversion. it can also be done using a crv motor which is 2.0 ltrs. sounds like your kinda new to hondas so my advice is to research lsvtec, ls/v, crvtec and vtec conversion. if you look on the upper right hand corner you will see a search button. click it and enter your topic. also click on the "archived" button for a lot more threads. it would really help to read the forum rules. people flip out when new guys that are too eager to learn skip reading the rules and post questions that have been covered 1000 times a day. good luck and READ READ READ before you ask. oh yea welcome to h-t
Old Apr 28, 2008 | 12:50 PM
matmcg's Avatar
just use duct tape its much easier
Old Apr 28, 2008 | 12:58 PM
Jimmy's Avatar
Global Moderator
Read this thread..
https://honda-tech.com/zerothread?id=1676914
and this one
https://honda-tech.com/zerothread?id=1812388
And read this one if you have any other questions.. check to see if it's been posted before.. We try to cut down on repeated topics..
https://honda-tech.com/zerothread/1230496
Also since your a new member.. i suggest reading the forum rules
https://honda-tech.com/zerothread/2258865
Welcome to h-t.
Old Apr 28, 2008 | 01:15 PM
Rickdrizzle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dumbizzle &raquo;</TD></TR><TR><TD CLASS="quote">would that make a big difference or not really? or can i even do that?</TD></TR></TABLE>
Look in your upper right hand corner. It should say search. Heck, they were even kind enough to make it in red.
Old Apr 28, 2008 | 02:47 PM
LShatchie's Avatar
Default Re: can i bolt on a Vtech head to a B18b1 non vtech (Rickdrizzle)
NO!!
Old Apr 28, 2008 | 07:03 PM
{Sigur-Ros}'s Avatar
Default Re: can i bolt on a Vtech head to a B18b1 non vtech (LShatchie)
your a vtec
Old Apr 29, 2008 | 05:22 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LShatchie &raquo;</TD></TR><TR><TD CLASS="quote">NO!!</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by {Sigur-Ros} &raquo;</TD></TR><TR><TD CLASS="quote">your a vtec</TD></TR></TABLE>
Need I remind you?
https://honda-tech.com/zerothread/2193784
Old Apr 29, 2008 | 11:47 AM
Dbarnett88's Avatar
Search button is your friend! ton of results by even typing it into google
Old Apr 29, 2008 | 12:15 PM
LShatchie's Avatar
Default Re: can i bolt on a Vtech head to a B18b1 non vtech (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">
Need I remind you?
https://honda-tech.com/zerothread/2193784</TD></TR></TABLE>
im sorry didnt know, now i do
Old Apr 29, 2008 | 01:53 PM
akandok's Avatar
search in the forums "how to build a reliable ls/vtec" it should be in ALL MOTOR section.
Old Apr 29, 2008 | 04:35 PM
thisandee's Avatar
LOL
Old Apr 29, 2008 | 07:41 PM
Mfoehrkolb's Avatar
Old Apr 30, 2008 | 05:51 AM
LShatchie's Avatar
Default Re: can i bolt on a Vtech head to a B18b1 non vtech (jdmeg6118)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmeg6118 &raquo;</TD></TR><TR><TD CLASS="quote">No you can not wont work whatsoever no such thing man...... </TD></TR></TABLE>
please read the forum rules, i made the same mistake buddy
Old Apr 30, 2008 | 06:06 AM
lmike6453's Avatar
i think the op means can you just bolt on the head and not rev past 7k and have the oil flowing well in vtec without fitting an additional line in the head...
i read all the vtec builds on this site and i dont remember it specifying whether or not you can, reliably
natebaur
Oct 18, 2009 03:59 PM
bomber217
Jul 13, 2009 03:18 PM
tractionless
Apr 26, 2006 11:47 AM
T--Rex
Jul 26, 2004 07:38 AM
jowy
25
Apr 10, 2004 05:34 PM
