Questions about CTR suspension on an EX 00 coupe
Old Apr 28, 2008 | 10:32 AM
chuboia's Avatar
Default Questions about CTR suspension on an EX 00 coupe
Hey guys, I have a Civic 00 ex coupe, and I'm going to get a set of CTR's springs+struts as in picture 2 below.
Do those CTR's front springs+struts work with my ex front LCA's? and for the rear's in the pic 2, are they missing the U-shaped bottom mount, circled in pic 1?
Looking at the picture 2, can anyone know if they are authentic CTR's springs+struts?
Thanks
Pic 1
pic 2
Old Apr 28, 2008 | 11:05 AM
chuboia's Avatar
any ideas guys? thanks.
Old Apr 28, 2008 | 12:09 PM
scrooge's Avatar
Default Re: (chuboia)
hey as far as i know working at a japanese parts/importer shop for car parts the 92-00/94-01 integra have the same exact shocks as the usdm and the JDM only difference that ive noticed is the rear for 92-00 civics and 94-01 integra EVERY SINGLE ONE OF THEM come with no forks and they come with the lower control arms
so to answer your question that could be just stock shocks/springs for whatever car it maybe (92-00 civic or 94-01 tegra) unless the ctr has a different spring rate/different shocks than a stock ek but that i dont know soo thats wat i know hope i helped
Old Apr 28, 2008 | 12:52 PM
pdiggitydogg's Avatar
Fronts are fine
Rears, you need type r specific lower control arms - as shown in the picture
Old May 29, 2008 | 08:12 PM
abe amigon's Avatar
Default Re: (pdiggitydogg)
Your pic #2 is ITR suspension. CTR's have the same rear LCA's as your 2000 civic EX coupe.
If you want to install ITR rear LCA's, they will not fit.
Just look at the sway bar end links. those are for DC and EG not for EK.
Make sure you know what you're getting before you buy anything.
Old May 29, 2008 | 09:18 PM
NOFX's Avatar
H-T White Ops
sk8shorty did this to his coupe IIRC. You might be able to direct some questions to him.
Old May 29, 2008 | 10:45 PM
x0!'s Avatar
x0!
from looking at pic 2.
it wont be a direct bolt on for your 00 coupe. it would on 92-95civic/94-01integra.
Old May 30, 2008 | 12:26 AM
BlueIntegraBoy's Avatar
Default Re: Questions about CTR suspension on an EX 00 coupe (chuboia)
In order to use the ITR suspension, you will need Function7 "Type-R" Style LCAs for a 96-00 Civic.
Revlon Charly
Mar 14, 2007 06:26 PM
PHAT R 390
Sep 10, 2004 06:45 AM
