Injector swap questions
Old Apr 28, 2008 | 10:05 AM
ls-vtEK4's Avatar
From: Ontario,where cops smash ur cars and make you watc, CA, US OF A
Default WhatTheFruit!!! injector swap..
ok I'll try to make this brief...I built a LS vtec ( b18a block, GSR head)and I used my sohc non vtec injectors (d16y7 i think 190cc injectors) just so I can start it up (didn't have $ for new injectors) and they worked fine...other then not being the correct injectors....anyway.....i finally got some obd2 GSR injectors and when I swapped them in voila engine sounded so much better (at idle).....here's the problem...when I gave it gas it felt like it wanted to die on me...it wouldn't accelerate. it would sputter like a ****...what can it be? I was told the injectors were in perfect working condition when i bought them (use of course) ohm test showed 12.1-12.2..I searched and showed no other cases.
Modified by ls-vtEK4 at 2:36 PM 4/28/2008
Old Apr 28, 2008 | 10:06 AM
ls-vtEK4's Avatar
Default Re: WhatTheFruit!!! injector swap.. (ls-vtEK4)
help bump!!
Old Apr 28, 2008 | 10:11 AM
00b18b's Avatar
possible vacuum leak?....injector seals
Old Apr 28, 2008 | 10:37 AM
ls-vtEK4's Avatar
Default Re: (00b18b)
i replaced all the inj. seals..they are fresh as can be.
Old Apr 28, 2008 | 11:45 AM
bubby26nj's Avatar
Default Re: (ls-vtEK4)
if you have a a/f meter see what its running at. 14.7 to 1 is best for everyday driving. if its running leaner than that its a fuel problem. the only other easy problem i can really see is a bad o2 sensor in which case you arent getting enough fuel.
Old Apr 28, 2008 | 01:35 PM
ls-vtEK4's Avatar
Default Re: (bubby26nj)
don't have one...thanks tho.
Old Apr 29, 2008 | 04:02 AM
Acidcrakker's Avatar
So when you had the old injectors before, the car would not run like crap. But with the new injectors they run like crap.
How long did the injectors sit before they were sold to you. If injectors sit for long periods of time they will gunk up on the inside. Take them to a shop and have them tested and or recleaned.
The awnser is pretty obvious here.
Old Apr 29, 2008 | 07:20 AM
ls-vtEK4's Avatar
Default Re: (Acidcrakker)
i was able to tell that the other injectors (d16y7) were being pushed to their limit but it was running....the guy i bought them from said they were tested and were in perfect working condition but I did not ask whether they sat around or not...I did get a 9v battery and tested them, they all clicked which I assume mean they are not stuck. I guess the best thing would be to take em in. Thanks!
Old May 1, 2008 | 07:40 PM
dr.garagetuner's Avatar
take a test light and the injector and place the end of the injector in a plastic bottle (while its still hooked up to the harness) and take the test light probe and hook up the lead to a 12v source such as ur battery. Probe the injector, if they are working right you will see it spray into the bottle. Try that out and see if it works thats how i tested my injectors. Good luck.
jyracer
Nov 23, 2009 05:56 AM
DieMaster
14
Apr 7, 2006 08:26 PM
Sketch_hs
Nov 13, 2005 10:33 AM
h22acivicman
Apr 12, 2004 04:52 AM
TurboJesse
Jun 29, 2003 04:31 PM
