My compression numbers, am I good to turbo it?
Old Jul 12, 2002 | 06:24 PM
Smooth-GSR's Avatar
Default My compression numbers, am I good to turbo it?
1999 Integra GS with 52,000kms.
My numbers were 175 on all four, cylinder 3 was a little lower at ~170, going left to right from passenger to drivers side.
Mind you this was on a cold engine, I forgot I had to do it when it was warm. How much of a difference can that mean?
Am I good to turbo it? I would like to add a T3 and keep in on stock internals and less than 10psi, to get me in the 13's.
Any comments??
Old Jul 12, 2002 | 09:24 PM
rioninja's Avatar
Default Re: My compression numbers, am I good to turbo it? (Smooth-GSR)
Test it again warm, if your worried. If it was mine, i'd boost it
Old Jul 12, 2002 | 09:52 PM
DIRep972's Avatar
Smarter than you
I wouldnt even think twice. boost it baby!
Old Jul 13, 2002 | 01:56 AM
civictypenos's Avatar
how do you take a compression test exactly,just pull the plug,screw in gauge and turn the motor over right(after disconnecting the coil).i got 190,190,200,190 in my b16a3,does that sound right?or was there something i didnt do.
how many times do you turn the motor over,alot or just like 1 or 2 times or what?
[Modified by civictypenos, 10:57 AM 7/13/2002]
Old Jul 13, 2002 | 03:30 AM
Smooth-GSR's Avatar
Default Re: My compression numbers, am I good to turbo it? (civictypenos)
Thanks for the input everyone, I think it should be ok, since that was cold,it'l be a bit higher when warm, boost here I come!!
Take out all the plugs and wires, put the gauge in the first cylinder and turn it over about 5-7 times with the throttle to the floor. Do it for each cylinder a few times to ensure the numbers are consistent, be sure to do it when the car it warm.
That's it...
Old Jul 13, 2002 | 06:30 AM
CovertFI's Avatar
hmm i always disconnect the fuel pump relay so i am not shooting out fuel. 4 times should be plenty. i also get good readings even with the tb closed. i get 210 across the board in a d16y8.
eksleeper96
Apr 23, 2011 04:05 PM
Ricer no 7
Mar 11, 2008 12:53 PM
b18bme
Nov 26, 2006 07:40 PM
IntegraLs94Cam
Jun 5, 2004 10:45 PM
cu3tip
Mar 14, 2004 09:03 PM
