Door Chime?
Old Apr 28, 2008 | 08:18 AM
ImPuLsIvE's Avatar
Default Door Chime?
Where's the chime relay that activates when the keys are left in the ignition (on acc) and the door opens?
Other than the actual chime disappearing, are there any issues that could arise from removing the relay?
Old Apr 28, 2008 | 09:57 AM
CentralCalLude92's Avatar
Default Re: Door Chime? (ImPuLsIvE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImPuLsIvE &raquo;</TD></TR><TR><TD CLASS="quote">Where's the chime relay that activates when the keys are left in the ignition (on acc) and the door opens?
Im pretty sure it is next to the fuse box under the dash.
Im not sure if anything else is using that relay. But if you are concerned about causing an issue and just want to eliminate the sound from opening the doors, just unplug the sensors.
4door90
Feb 1, 2005 11:19 AM
SPLNRSX
May 9, 2004 07:35 PM
Spooled1.6L
Apr 20, 2004 09:11 PM
b18c5T
May 27, 2002 11:01 PM
