Blox 76mm Throttle Body Sticking
Old Apr 27, 2008 | 09:10 PM
integrainside's Avatar
Default Blox 76mm Throttle Body Sticking
Just put a brand new Blox 76mm throttle body on my turbo B18C1, and now im having a problem with my throttle sticking. When i remove the trottle body from the car, i cant get it to stick. But when its on the car it sticks whether the throttle cable is connected or not. Any Advise?
Old Apr 27, 2008 | 09:13 PM
bpr0422's Avatar
Default Re: Blox 76mm Throttle Body Sticking (integrainside)
if its sticking.... it could be hitting the IM opening...
if the IM opening is smaller than 76mm, you need to grind it open...
Old Apr 28, 2008 | 02:34 AM
roycivic92's Avatar
Default Re: Blox 76mm Throttle Body Sticking (bpr0422)
wow 76mm thats really big. port out the im.
Old Apr 28, 2008 | 04:39 AM
The intake manifold has already been port matched to the throttle body.
Old Apr 28, 2008 | 05:08 AM
chimmike's Avatar
Default Re: (integrainside)
could your throttle cable be sticking on something?
Old Apr 28, 2008 | 05:33 AM
It sticks even with the throttle cable removed. It only sticks open when its slightly opened up.
Old Apr 28, 2008 | 08:09 AM
h2b_sedan's Avatar
well from what i can gather from what you said its definately getting caught on the intake mani. look inside the throttle body when your opening it and see if its touching the manifold
Old Apr 28, 2008 | 12:53 PM
Default Re: (h2b_sedan)
I had the manifold bored out by a machine shop to port match it. The butterfly doesnt come anywhere near the manifold
Old Apr 28, 2008 | 12:59 PM
pdiggitydogg's Avatar
https://honda-tech.com/zerothread?id=457316
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">It could also be the throttle plate itself... Pop the throttle plate open with your fingers using the cable pulley... Does it stick a bit when you try to open it up again? (as in it's initially hard to open) If so the problem is most likely just the plate itself... Loosen the two set screws that hold the plate and bleep it open and closed a few times... Tighten the screws back up and if it still stick then adjust the pulley set screw... It has a lock nut on it so you first have to break that loose... After that with an allen wrench very slowly turn the screw counter clockwise, opening up the throttle body... This will fix the sticking just about anytime because most of the time the throttle plate is trying to close too much when it's resting at it's idle position which therefore makes it bind... Hope you can understand this and good luck... Peace</TD></TR></TABLE>
Old Apr 28, 2008 | 01:14 PM
VSMhatchy's Avatar
Most aftermarket throttle bodys tend to stick. Mine does this.
Old Apr 29, 2008 | 11:50 AM
Blox is going to warranty it, i sent it back today... I'll let ya know how it goes
Tippyman
Jul 27, 2013 10:20 AM
monkalotamus
Nov 15, 2006 06:31 PM
redGSRguy
Feb 6, 2006 08:58 AM
clutcher
Apr 21, 2005 05:25 PM
