Launching with 2 step (launch control)
Old Apr 27, 2008 | 06:23 PM
CRXherbie91's Avatar
Default Launching with 2 step (launch control)
i was wondering, when launching with launch control if you just dump the clutch.. is it the same as just dumping the clutch without using it.. is that what your suppose to do?.. is it as bad on the drivetrain as it is without using launch control?.. will it still break axles?..
Old Apr 27, 2008 | 07:11 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
Default Re: Launching with 2 step (CRXherbie91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXherbie91 &raquo;</TD></TR><TR><TD CLASS="quote">i was wondering, when launching with launch control if you just dump the clutch.. is it the same as just dumping the clutch without using it.. is that what your suppose to do?.. is it as bad on the drivetrain as it is without using launch control?.. will it still break axles?.. </TD></TR></TABLE>
of course it's bad, it's just strain on ur drivetrain.. but it's just the matter of how you preload your clutch when u launch, you might be burnin ur clutch but it'll be worth it when u don't break axles or mess other things up
Old Apr 27, 2008 | 08:10 PM
Garage 808 Hatch's Avatar
Default Re: Launching with 2 step (ohsnapzafingcu)
the usage of a 2 step is to provide consistant launches, build boost at the line on turbo cars. you can still use it and preload, (i dont) but many do
Old Apr 27, 2008 | 10:56 PM
yea.. i understand what your saying.. i may have kind of asked the question.. wrong.. with my 2 step when it launches it gets up to 6mph and then it starts to pull/spin and thats when all the power is started after 6mph....
maybe i should of said.. is it still neccessary to preload when using 2step.. since all my power isnt let loose until after 6mph..is it still hurting my drivetrain and stress on my axles?
Old Apr 28, 2008 | 04:39 AM
Default Re: (CRXherbie91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXherbie91 &raquo;</TD></TR><TR><TD CLASS="quote">yea.. i understand what your saying.. i may have kind of asked the question.. wrong.. with my 2 step when it launches it gets up to 6mph and then it starts to pull/spin and thats when all the power is started after 6mph....
maybe i should of said.. is it still neccessary to preload when using 2step.. since all my power isnt let loose until after 6mph..is it still hurting my drivetrain and stress on my axles? </TD></TR></TABLE>
preloading is recommended if u have stock axles, or if you don't want to break em.. and all the racing u do will hurt/stress ur drivetrain. but it should take the abuse if you preload right
Old Apr 28, 2008 | 05:05 AM
1992Si's Avatar
Simple answer, yes always preload, it saves drive line parts.
Watch the videos of how the TurboStreet and Pro's do it.
Oh yea, don't do a dry hop after your burnout. That's when lots of guy snap axles.
Old Apr 28, 2008 | 09:13 AM
streetracer6rpt's Avatar
Default Re: (1992Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1992Si &raquo;</TD></TR><TR><TD CLASS="quote">Simple answer, yes always preload, it saves drive line parts.
couldnt have said it better myself
Old Apr 28, 2008 | 09:40 AM
1992Si's Avatar
Default Re: (streetracer6rpt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetracer6rpt &raquo;</TD></TR><TR><TD CLASS="quote">
couldnt have said it better myself </TD></TR></TABLE>
Thanks, yea, sometimes us old guy's got this new stuff figure out. Actually I need to give my son rota92 credit for getting into this.
Old Apr 28, 2008 | 01:38 PM
StolenTeg's Avatar
For those with anti-lag, when do you get on it during staging? Once the amber light start counting down?
Im afraid to get on mine too long and damage something
Old Apr 28, 2008 | 01:55 PM
1992Si's Avatar
Watch the vid's.
They seem to pre-stage, then pull up the e brake a bit, push the button, push the gas, let up on the clutch and drag the car into the second beam, pull up and the ebrake a little to stop the car. Wait for the lights. That's pretty much what Ryan has told me.
Big hint, if you see green, you lose. I taught Ryan that.
Old Apr 28, 2008 | 03:08 PM
Newt Dog's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1992Si &raquo;</TD></TR><TR><TD CLASS="quote">Watch the vid's.
Big hint, if you see green, you lose. I taught Ryan that. </TD></TR></TABLE>
You hit that right on the money!
BJA86
Jul 18, 2007 10:47 AM
92hatchattack
Apr 6, 2007 07:27 PM
strtrcr77
Mar 20, 2007 08:47 AM
D-meet07
Dec 31, 2006 10:11 AM
CheeseKT
Jan 12, 2004 01:38 PM
