can i use a ls header on a b16 head?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PadJSRmotors »</TD></TR><TR><TD CLASS="quote">it will not fit unless u mod it up lol</TD></TR></TABLE>
um, wrong im running a stock LS header on my LS/V with a B16 head. yes it will fit, a b16 stock header on the other hand will be a little shorter if you run it on a B18 motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_si-r »</TD></TR><TR><TD CLASS="quote">
um, wrong im running a stock LS header on my LS/V with a B16 head. yes it will fit, a b16 stock header on the other hand will be a little shorter if you run it on a B18 motor. </TD></TR></TABLE>
correct. exhaust ports i believe are the same on all b-series.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ice78transam »</TD></TR><TR><TD CLASS="quote">
correct. exhaust ports i believe are the same on all b-series. </TD></TR></TABLE>
skiracer8148
Mar 3, 2007 01:18 PM
