Transmission help please!!
what does it mean when ur car shakes as it's engaging into first gear? i recently changed the clutch slave and master cyl and bled out the lines completely. could it be a bad pressure plate or throw out bearing?
it all started when i misshifted and as a result got locked out of all of my gears. i checked the clutch fluid and it was low, refilled, and after a little it went back to normal. i then changed the cylinders (because the leaks were from there) and now im feeling a vibration as i go into first gear.
So the car shakes while you have the clutch pedal pushed in and you are shifting into 1st gear or it shakes when you are in 1st gear and you are letting the clutch out?
If you misshifted, I would guess you likely messed up the clutch disk.
I have the same issue with my ACT 6 puck unsprung clutch (over kill for my setup). I recently put mine in so I am hopping its something that I need to get use to. If I give it more throttle then I would previously and feather the clutch a little more, its seems to transition better with less "bounce"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokedyou19 »</TD></TR><TR><TD CLASS="quote">try giving it a little more gas as you release the clutch</TD></TR></TABLE>
i do, and i does help, but it just doesnt feel right. i dont think it should be doing it. especially since it wasnt doing this before.
i basically wanna if the shaking is a classic symptom of any specific part thats the problem (warped flywheel, throw out bearing, clutch, pressure plate, etc)
yeah i have a six puck and it chatters too, its normal for six pucks, unless you didn't resurface the flywheel when you changed the clutch that can do it too.
Bowl_of_Rice
Dec 29, 2011 05:34 PM
supercivicstack
Sep 12, 2009 02:24 PM
old_school_dohcvtec
Oct 4, 2007 09:47 AM
Nick248
May 29, 2002 07:28 AM
