Hasport EG Hyrdo-Cable Trans Conversion Questions.
So i recently purchased a 93 hatch b16a with a transmission out of a 91 da. My drivers side axle is pretty shot. and i have no idea what kind of car i should tell the parts store when i go get a new one. the guy i bought it from said 94-00 integra but i dont want to be messing around with going back and forth. can anyone confirm this?
what intermediate shaft are you using?
you would use the same year axles as intermedite shaft
male end would be 94-01 integra
female end would be 90-93 integra
as for the intermediate shaft i really have no idea. all i know is it is a b16a and it is using a 90-91 integra trans or atleast that is what kind of clutch i would need to purchase to use on the car. so basically i have to put 2 different kinds of axles together to make the right one?
What Hasport is saying is that your car could have either the 90-93 Integra axles OR the 94-01 Integra axles. The difference is the 90-93 Integra axles have a male inner joint on the drivers side and the 94-01 Integra axles have a female inner joint on the drivers side. You will probably need to remove the axle from the car to tell which one you have as it is hard to tell the difference when the axle in installed in the car.
ITR632
Apr 21, 2003 01:24 PM
ITR632
Apr 21, 2003 12:09 PM
