completely stumped...
Old Apr 27, 2008 | 12:36 PM
The Dirty EJ1's Avatar
Default completely stumped...
pr3 b16... pulled the motor and put back in... i cant figure out why my car wont start, i have compression, fuel and spark but for some ODD reason my car will not start and run. Ive checked basically everything but anyone have any ideas one my problem??
oh and yes i have the grounds, neg battery to chassis, tranny to chassis, harness to thermo stat, and valve cover to core support.
thanks allot,
spenser
Modified by The Dirty EJ1 at 1:53 PM 4/27/2008
Old Apr 27, 2008 | 12:56 PM
TomTread's Avatar
Default Re: completely stumped... (The Dirty EJ1)
check your crank sensor see if it is disconnected, or if you have a bad connection throughout your harness. i had a similar problem with my civic si. did you advance or retard your timing at all when you had the engine pulled. if so that would effect starting and idling.
Old Apr 27, 2008 | 01:03 PM
Default Re: completely stumped... (TomTread)
ill check the crank sensor, but i reset the timing.... so that cant be it.
Old Apr 27, 2008 | 01:47 PM
TomTread's Avatar
do you have any access to a info scanner. that tells you fuel trims or anything like that? also if you can get a set of NOID LIGHTS that will tell you if your injectors are firing. the only other thing i can think of is get a diagram of your plug wires on the distributor cap. and check to see if the wire are on the right cylinder.
klh2000
Honda CR-V & Element
Nov 22, 2020 04:08 AM
MitchHamilton
15
Oct 25, 2016 05:00 AM
jonnybadboi9
Jul 15, 2009 09:39 PM
mygfs92lx
Jul 19, 2006 06:33 PM
