piggy back info
Old Apr 27, 2008 | 12:18 PM
Tytank7's Avatar
Default piggy back info
i want a v-tec controler and ive been looking at the Apexi SAFC NEO but i was wondering how hard the install would be and what i need to install is it just plug and play?
Old Apr 27, 2008 | 12:22 PM
98vtec's Avatar
moderator emeritus
Default Re: piggy back info (Tytank7)
http://www.boomslang.us
OBD2A
Old Apr 27, 2008 | 12:25 PM
Tytank7's Avatar
Default Re: piggy back info (98vtec)
so i need that to make it plug and play?
Old Apr 27, 2008 | 12:27 PM
98vtec's Avatar
moderator emeritus
that would be the point.
Old Apr 27, 2008 | 12:31 PM
Tytank7's Avatar
so say i didnt buy it i just buy it from apexi what am i going to have to do to install?
Old Apr 27, 2008 | 01:19 PM
98vtec's Avatar
moderator emeritus
figure out which wires on the afc need to be tapped into which wires on the ecu wiring harness. cut, solder, heat shrink.
Old Apr 27, 2008 | 01:40 PM
Tytank7's Avatar
okay well i thank i might get that harness then
Old Apr 27, 2008 | 05:07 PM
Sir Kyle's Avatar
I got that harness for mine and it turned a two hour install into about 15 minutes. Worth every penny!
Old Apr 27, 2008 | 05:45 PM
Tytank7's Avatar
Default Re: piggy back info (Sir Kyle)
so could u explain the install cuz i hate wires they confuse the hell out of me
Old Apr 27, 2008 | 05:51 PM
Sir Kyle's Avatar
Basically the harness is an extention of your ecu harness and has the Neo cable hooked into it. All you do is unplug your ecu and plug in the boomslang in its place. Its like the definition of plug and play. Make sure you go threw all the setting on the Neo before you start the motor though.
Old Apr 27, 2008 | 06:07 PM
Tytank7's Avatar
ight thanks and by the way did u have the center of your hood painted black?
Old Apr 27, 2008 | 06:45 PM
Sir Kyle's Avatar
Ha, no I had the outside of my cf hood painted red.
Old Apr 28, 2008 | 09:07 AM
Tytank7's Avatar
well i realy like that look other than the c/f its like a hot rod with there flat black hoods
but any way thanks for the info
Old Apr 28, 2008 | 12:05 PM
snobordboy's Avatar
Moderator
I would recommend the Boomslang harness as well, i have one in my 4th gen, fit perfect, made the install super fast, and if you want to take it out its a simple unplug job, not cutting and soldering etc all over again. Also usefull if you just wanted to temporarily remove it from the car etc. Plus laying down in the footwell to cut and solder, not so fun!
$MIKE$
Jun 12, 2014 02:04 PM
withoutlimitslude
Mar 25, 2009 10:01 PM
civicstar
May 23, 2007 04:34 PM
justint
Audio / Security / Video
May 19, 2006 04:51 AM
Sonik_fury
Sep 11, 2005 01:39 PM
