"Reverse" mini-me timing belt issues
Old Apr 27, 2008 | 06:42 AM
Snafubmx234's Avatar
Default "Reverse" mini-me timing belt issues
Z6 block/waterpump/tensioner
A6 head
A6 timing belt is too long, Z6 is just a bit too short.
I know, from a quick search, that the Z6 belt has 104 teeth, while the A6 has 107, and they both have the same deck height (212mm)
I could try to find a 105/106 tooth belt, or, if one of you would be so kind, compare my tensioner (that I bought at CarQuest) to an OEM one.
Using a mic I measured my tensioner diameter - 52.80mm or 2.078in
Maybe the A6 tensioner would help pick up the slack in the A6 belt... I guess I don't know at this point and need advice.
Thanks,
Colin
Old May 5, 2008 | 08:03 PM
Default Re: "Reverse" mini-me timing belt issues (Snafubmx234)
bump
Old May 8, 2008 | 05:05 PM
Ocnaj's Avatar
Couldn't you use the Y8 belt? If I'm not mistaken doesn't it have 105 teeth? Correct me if I'm wrong
Old May 9, 2008 | 08:10 AM
Default Re: "Reverse" mini-me timing belt issues (Ocnaj)
I've heard that or a VX belt. I guess I'll just buy each belt and count the teeth
Old May 9, 2008 | 07:25 PM
Bense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Snafubmx234 &raquo;</TD></TR><TR><TD CLASS="quote">I've heard that or a VX belt. I guess I'll just buy each belt and count the teeth </TD></TR></TABLE>
vx belt is 103 teeth
d15b7 belt is 106 teeth
ej1noob
11
Jun 16, 2011 12:01 AM
dcwoodard
Oct 5, 2008 05:29 PM
ef-hatchcrap
Apr 18, 2008 03:43 PM
ef-hatchcrap
Feb 21, 2008 04:35 PM
StupidSlowRSX
Feb 15, 2008 03:00 AM
