Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Softest aftermarket spring kit
Old Apr 27, 2008 | 05:05 AM
heel n'toe joe's Avatar
Default Softest aftermarket spring kit
Hi guys! New to the forum. my wife and I are looking at new Civic LX sedans and want to do a +2 wheel upgrade and a aftermarket spring kit.
My question is what's the concensus on the aftermarket lworing spring kit that has the best ride quality?
I would assume if a company made a street lowering spring kit with street specific spring rates, that I could retain the factory shocks. Has anyone doe this with success?
I have already searched for this with no luck. thanks in advance!
Old Apr 27, 2008 | 06:18 AM
SIVIC 3's Avatar
whats a +2 wheel upgrade??
most people on here have their springs paired up with the stock struts, unless they have coilovers. I personally like my TEIN's s-tech (there are quite a few threads regarding springs)
Ive also heard progress makes a nice set.
Eibach, Skunk2, are some of the others.
Look around youll see what Im talking about.
Old Apr 27, 2008 | 06:33 AM
Default Re: (SIVIC 3)
+2 means you're going up 2" in wheel diameter. (from a 15" to a 17" wheel)
I found these on The Tirerack for $360 a set. 17x7. I think they would fit my wife's tastes pretty well without looking to "teenagerish"
How is the ride of your Stechs vs stock?
I did some research on the Htechs. They seems to be a great street spring choice as well:
From Tein's site:
"TEIN High.Tech springs utilize the latest spring and material technology to optimize comfort, performance, and quality. Designed and tested in North America to be used in conjunction with OEM or similar shocks for excellent ride comfort and slightly increased handling. The line is produced with Vanadium (SAE9254V), which is durable, lightweight, and has properties to retain more spring stroke. High.Tech springs are designed for those seeking a slightly lowered stance while maintaining high ride quality at a reasonable price. Most vehicles will attain a 1.2 inch drop for a more attractive appearance, added performance, and excellent comfort. Includes a one year limited warranty."
...The car is for my wife and it will never be driven above 7/10ths. I'm just looking to slightly decrease the wheel gap without running into bottoming out or a harsh ride. I hate to throw away brand new dampers for aftermarket ones that will probably increase the ride harshness.
Old Apr 27, 2008 | 08:40 AM
ju5tchi11in's Avatar
Default Re: (heel n'toe joe)
you my want to look into stock last gen TL wheels, or rsx-s wheels similar 5 spoke while retaining Honda/Acura styling "non-teenagerish."
Keep your stock springs if you do upgrade.
Another option for you is the HFP suspension package. Will give you "OEM quality" ride with improved handling and better appearance.
Old Apr 27, 2008 | 09:13 AM
elohel's Avatar
Default Re: Softest aftermarket spring kit (heel n'toe joe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by heel n’toe joe &raquo;</TD></TR><TR><TD CLASS="quote">Hi guys! New to the forum. my wife and I are looking at new Civic LX sedans and want to do a +2 wheel upgrade and a aftermarket spring kit.
I have already searched for this with no luck. thanks in advance!</TD></TR></TABLE>
If you lower the car, it's more than likely going to be stiffer. Not only that, but no lowering shocks are really made to retain the OEM shocks. You'll just wear them out quicker over time.
Old Apr 27, 2008 | 10:32 AM
Default Re: (ju5tchi11in)
Thats an excellent idea! The TL has the correct offset and hub diameter? Also, can you get honda center caps for the wheels? Is this a TL specific thing, or can we get some TSX wheels also?
Anyone have pics of this setup?
Old Apr 27, 2008 | 11:32 AM
I found this guys car on 8thcivic.com:
TSX wheels and a reasonable drop with a slight tint... Thats pretty much exactly what we're looking for.
Maybe a lound shinny pipe hanging out the back... maybe not!
Old Apr 27, 2008 | 01:39 PM
Skilz10179's Avatar
Look into HFP suspension, its supposed to be stock ride quality.
2camsaam
Aug 5, 2014 04:48 AM
Duc_du
Suspension & Brakes
Apr 28, 2009 02:25 PM
beecee
Suspension & Brakes
Mar 11, 2008 11:58 AM
b18LS
Suspension & Brakes
Aug 25, 2007 03:29 PM
vaporDA6
Mar 11, 2004 11:07 AM
