obd1 tuning pgmfi logworks
Old Apr 26, 2008 | 05:31 PM
nickromeo's Avatar
Default obd1 tuning pgmfi logworks
hey has anyone here been able to log their ecu data in logworks somehow?
cant get any thing to work!
anybody?
my logging works fine with freelog and ecu control
Old Apr 26, 2008 | 06:46 PM
borat's Avatar
Default Re: obd1 tuning pgmfi logworks (nickromeo)
Last I tried, it only worked with an outdated version of crome. It isn't even worth it, I find logworks very tedious to use.
Get ectune, it has direct serial input from innovate widebands into its native datalogger.
Old Apr 27, 2008 | 06:10 AM
nickromeo's Avatar
im am considering getting ectune but would like to leave it as my last option when i give up.
i dont get it why no software works for logworks but freelog and ecucontrol work fine.
i am using a p06 on uberdata with j12 still in tact.
i beleive that the solution is out there but no one can code a applicable plugin for the software!
something to do with different dATAlogging protocols or something????
Old Apr 27, 2008 | 06:20 AM
RACEPAK's Avatar
i'm using logworks to log my engine, but with a lma-2(rpm conv)
i never managed to log directly from the ecu (freelog do work)
Old Apr 27, 2008 | 08:55 AM
nickromeo's Avatar
Default Re: obd1 tuning pgmfi logworks (RACEPAK)
RACEPAK thank you for your answer.
are u also logging map sensor to your lma2?
because i would like to log map and rpm.
i own an lc1 and mite be forced to buy an ssi4 to log what i want with logworks.
i find it absolutely rediculous that no one has had luck with pgmfi stuff into logworks!
Old Apr 29, 2008 | 10:55 AM
RACEPAK's Avatar
no prob.
yes i'm logging:
ARF
RPM
MAP
TPS
iat and ect somtimes work... but they are not calibrated real good,
i can email you the map scalei got if you want, (its a txt file)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickromeo &raquo;</TD></TR><TR><TD CLASS="quote">
i find it absolutely rediculous that no one has had luck with pgmfi stuff into logworks!</TD></TR></TABLE>
true, innovate is kinda slow with their products,
+ i dont see the new LM2 getting relesed in the near future...
drumri0t
Jan 25, 2016 06:19 AM
Type_BB6
Mar 2, 2010 03:23 PM
e-g-6jdm
Feb 9, 2008 01:56 PM
Thagreybomber
Jun 17, 2002 09:17 PM
