CRX with teg LS engine.. question
Old Apr 26, 2008 | 05:14 PM
slask1's Avatar
Default CRX with teg LS engine.. question
How difficult would it be to change a distributor on this car? I'm new to all of this so any help would be appreciated.
The reason I'm asking is it needs a new distributor and I don't know if I should buy it or not.
Old Apr 26, 2008 | 06:11 PM
Loaded Butane's Avatar
Default Re: CRX with teg LS engine.. question (slask1)
Dizzy is real easy to change. You remove 3 bolts and the wires and voila.
edit- And if you cant figure that out I can prob come help you out with it since you are semi local to me.
Old Apr 27, 2008 | 09:03 AM
Deetz's Avatar
Crazy Honda Guy
Its a 10 minute install. As mentioned, only 3 bolts, and 2 plugs
Old Apr 27, 2008 | 11:00 AM
TOO MUCH TORQUE's Avatar
you have to make sure the timing is right as well. you cant just slap it on and expect it to work perfectly.
Old Apr 27, 2008 | 11:26 AM
barely4dr's Avatar
Default Re: (TOO MUCH TORQUE)
yes, make sure the motor is at spark tdc, then proceed to removal and install.
Haynes manual ftw
Old Apr 27, 2008 | 01:47 PM
welfarepc's Avatar
just mark the position of the old dizzy, put the new one on in the same posistion. easy
FYI a new distributor costs over $300
swisscheese32
Jun 28, 2011 03:35 AM
WhiteOnRice
20
Jan 5, 2009 07:50 AM
irishgod247
Mar 3, 2007 01:50 PM
spoon*honda
15
Sep 4, 2004 10:50 AM
hondaitegra
May 1, 2003 12:30 PM
