making my prelude '97 obd1.
Old Apr 26, 2008 | 01:49 PM
Flabah's Avatar
Default making my prelude '97 obd1.
Hi...
I have a Prelude from 1997.
I'm swapping my F20A4 engine into a H22A2.
All great and all fine, I was told that I have to cut of the orginele obd2 cable from the ECU to the engine. So I did...
Then I placed the ODB1 enginewirebundel in the car.
Now I've gor +-20 cables that I have to connect to the obd1 wirebundle. Now I'm looking foor the schemas for the wires, 'cause the colours are not the same:
On the left you see the orginel OBD2 cablebundle that goes into the car... on the right the OBD1 cablebundle were the ECU comes. But now I have to put the lose ends together, but I don't now witch colour needs to be witch colour... I hope you can help me. thx!
Old Apr 26, 2008 | 06:32 PM
1RMDave's Avatar
oh lord what have you done!?
for $100 you could have bought a jumper harness
Old Apr 26, 2008 | 06:39 PM
borat's Avatar
Default Re: (1RMDave)
$75 even.
http://www.xenocron.com/catalo....html
Whoever told you to cut into your harness needs to be slapped.
Oh, and to answer your question:
https://honda-tech.com/zerothread?id=2229290
Old Apr 26, 2008 | 06:53 PM
98vtec's Avatar
moderator emeritus
So if i understand this correctly, you want to run the OBD1 engine harness on your OBD2 interior subharness harness...correct?
man did you ever get some bad advice!!! You could have converted your OBD2 engine harness to OBD1 and bought an obd2 to obd1 conversion harness and been done with it.
wow, um. So you are doing this without having a clue what everything is. Well i'm gonna tell you that you are going to need to buy a service manual. preferably a helms or a factory service manual because they will have the pinouts and wire colors there for you and tell you their function.
I dont understand what you are telling me in the picture. The engine harness is only in the engine bay and connects to the interior sub harness right next to the shocktower. The OBD1 engine harness will not completely plug in to the OBD2 subharness and they are all pinned differently.
you got yourself into a mess.
Old Apr 26, 2008 | 07:07 PM
DfwBB6's Avatar
Default Re: making my prelude '97 obd1. (Flabah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flabah &raquo;</TD></TR><TR><TD CLASS="quote">
man o man thats going to be a freaking pain in the a$$
Old Apr 27, 2008 | 01:56 AM
Flabah's Avatar
oh... just great... I'm [freak]ed.
So I'm going to try to put my orginel engine harnas back to th interior harnas, I hope that that will work :/
Then I just buy a jumperharnas and I'm done?
Old Apr 27, 2008 | 04:17 AM
CHK4TIX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flabah &raquo;</TD></TR><TR><TD CLASS="quote">oh... just great... I'm [freak]ed.
Yah basically. But you have a mess on your hands. Hopefully you left enough wire on the connectors to work with.
Old Apr 27, 2008 | 06:14 AM
prelude1897's Avatar
yea, that's basicly all you have to do. If you still have your original harness, I'd suggest putting that back in. I got a jumper harness on ebay for only $65shipped....Don't forget that you'll also need an OBD 1 ECU. Here's a link to help decide which ones to get http://ntpog.org/forums/showthread.php?t=985
Old Apr 27, 2008 | 08:40 AM
Flabah's Avatar
Default Re: making my prelude '97 obd1. (prelude1897)
I'm just back from my car, I can put my original harnas together, but it's going to cost me a shitload of time.
that jumper harnas, I'm from Belgium... do you sent it to Belgium?
And I've got A p28 ECU fully mapped for this engine.
Old Apr 27, 2008 | 08:52 AM
98vtec's Avatar
moderator emeritus
to tell you the truth, putting the original OBD2 harness back together is the best/easiest/possibly cheapest option you have.
contact rywire, boomslang.us or phearable.net for a jumper harness.
If you arent planning on swapping parts to use the OBD2 harness properly, you will need to convert it to OBD1. This is very simple tho and I have a writeup for it in the FAQ.
for your OBD2 f20A motor, it likely has the CKP and TDC sensors mounted on the oil pump. For OBD1 motors, these sensors are located in the distributor. This means that in order to use your OBD2 harness on the OBD1 motor, you have to make a jump harness from the CKP/TDC sensor connector on the OBD2 engine harness to the OBD1 distributor.
this is how you do it:
http://bbmoto.net/wiki/index.p...rsion
If you have any questions let me know. You should have the same wiring schematics as the h22a4's. But let me know if you run into any trouble.
Old Jun 7, 2008 | 09:05 AM
Flabah's Avatar
Default Re: making my prelude '97 obd1. (98vtec)
*bump.
After working to long on my prelude... is he finally running!!
I'm not there yet, but it will be ok!
I rewired everything, whole harnass, that is a shitload of work.
http://www.youtube.com/watch?v=yw98do2VuCA
Click to see the running engine ^^
curiousgeorge1
Aug 21, 2009 11:39 AM
anonymus913
May 1, 2009 09:45 AM
mcloven
Jun 30, 2008 06:54 PM
cparreno
Mar 10, 2007 10:08 AM
kotetu
May 16, 2003 04:04 AM
