Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
18" hfp wheels
Old Apr 26, 2008 | 12:51 PM
redaf92's Avatar
Default 18" hfp wheels
Looking online at getting the 18'' HFP wheels, can only find them listed for the 06 and 07, assuming this is due to the TPMS, is there away to use these wheels and not lose that system, or is there another reason why they arent listed for the 08?
Old Apr 26, 2008 | 04:08 PM
redaf92's Avatar
Default Re: 18" hfp wheels (redaf92)
no love for the newb, swear i used the search fuction, so whuthuphux up with zephyr?
Old Apr 26, 2008 | 04:10 PM
2008fijibluesi's Avatar
Get them...the TPMS will work fine.
Old Apr 26, 2008 | 04:12 PM
redaf92's Avatar
Default Re: (2008fijibluesi)
thanks for the info fiji, can anyone else confirm or deny this?
Old Apr 26, 2008 | 04:30 PM
Default Re: (redaf92)
Watch this video...
http://youtube.com/watch?v=eCeoxXnsx9A
Old Apr 26, 2008 | 09:20 PM
av911's Avatar
http://www.diyhonda.com/2007_12_01_archive.html
Old May 1, 2008 | 12:13 AM
Icyrain's Avatar
The reason why you are seeing 06-07 listed for the wheel is that Honda changed the design slightly for the '08 HFP's. For the '08 models the area where the valve is was indented slightly on the inside part of the wheel to better fit the pressure sensors. In the 08 model the sensor will lay flat against the inside of the wheel. The 06-07 will work with TPMS. There will be about 2mm of space between the sensor and the inside of the wheel though. Just make a shim of foam tape or something and it should fit nice and good. The wheel finish was also changed in 08. The earlier models (06-07) were a bronze color and the new models are more of a silver. Check out http://www.handa-accessories.com/civext06.html and you will see pictures of both. They also say that the 08 HFPs they sell include TPMS sensors already installed. Hope that helps.
Modified by Icyrain at 1:23 AM 5/1/2008
Modified by Icyrain at 1:33 AM 5/1/2008
Old Jul 27, 2008 | 05:46 PM
krazyseaman's Avatar
does anyone know the diameter of the center cap for the bronze 06-07 hfp wheels?
tianporn
Jan 7, 2008 07:17 AM
FBPninetynineEM1
Nov 28, 2004 01:17 AM
xstalkrx
May 15, 2003 06:20 PM
