Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
tranny help
Old Apr 26, 2008 | 12:04 PM
ucc crx's Avatar
Default tranny help
i have a crx in the sm class. i have a ls supercharged and looking for a tranny. my question is which tranny would be my best bet. i was looking at a jdm itr with 4.7 fd or do you think i should get an itr with 4.4 fd
thanks
Old Apr 26, 2008 | 05:02 PM
FifthGearOnline's Avatar
Default Re: tranny help (ucc crx)
this is for auto cross im guessing. I don't think there would be much of a difference between a 4.4 and a 4.7.
side note: if this was GDD this thread would have taken a much more inappropriate turn
Old Apr 26, 2008 | 07:56 PM
Crx Jimmy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ucc crx &raquo;</TD></TR><TR><TD CLASS="quote">i have a crx in the sm class. i have a ls supercharged and looking for a tranny. my question is which tranny would be my best bet. i was looking at a jdm itr with 4.7 fd or do you think i should get an itr with 4.4 fd
thanks </TD></TR></TABLE> Nice to see another supercharged crx in the neighborhood, are you near peekskill? I dont know if it would make a huge difference in the final drive but a lsd would help the most.
Old Apr 27, 2008 | 07:06 AM
GI8U2racing's Avatar
The BEST option is a USDM ITR tranny with a different FD swapped in. The USDM had a smaller jump between 3rd and 4th gear, and is much easier to find. Then spend $300 for a FD, and you're good. I did a brand new OEM ITR tranny from Acura, swapped out the stock LSD to a Quaife, and an MFactory 4.9 FD, couldn't be happier.
For off the shelf being the best, I think USDM or JDM are just as good, the JDM one will have better gearing 1st, 2nd, 3rd though, which may be better for Auto-X
Old Apr 27, 2008 | 08:00 AM
ucc crx's Avatar
thanks for the replies i think im going to get a jdm itr with a 4.7 fd b/c i am getting a good deal on it
Old Apr 27, 2008 | 11:09 AM
slammed_93_hatch's Avatar
Default Re: (ucc crx)
Its an autoX car, he isn't going to see 4th gear.
I'd say it really depends on what your local courses look like, or if it is a national class what they tend to be.
ITR trannys tend to be too much money for what they are. It is a B16 tranny with a diff, that should be replaced any ways.
And you really only care about 2nd and 3rd gear, maybe a hybrid transmission would be your best bet.
Old Apr 27, 2008 | 11:22 AM
ucc crx's Avatar
i was thinking about buying a non lsd b16 and then putting a obx or quaife lsd (if i had the money for a quaife) in it. what is your opinion on an obx over a oem itr lsd
Old Apr 27, 2008 | 11:33 AM
I like Kaaz, never used anything else and don't really plane on it.
If you search around OBX is not something i would think you would want in your transmission
Old Apr 27, 2008 | 11:38 AM
ucc crx's Avatar
do you think the fd makes a big difference in autocross
Old Apr 27, 2008 | 12:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ucc crx &raquo;</TD></TR><TR><TD CLASS="quote">do you think the fd makes a big difference in autocross</TD></TR></TABLE>
I am not sure. I am don't really autoX
Old Apr 27, 2008 | 01:18 PM
bosco500's Avatar
That is a pretty generalized question. The FD could make a huge difference, it all depends on what gearing your starting with.
Old Apr 27, 2008 | 02:34 PM
ucc crx's Avatar
i was meaning with an itr is the 4.4 and 4.7 a big difference
Old Apr 27, 2008 | 02:38 PM
bosco500's Avatar
Autocrossing, probably not that much of a difference. Check this calculator out
http://www.fatboyraceworks.com/gears/
Old Apr 27, 2008 | 03:33 PM
vbspec's Avatar
Default Re: (bosco500)
Use one of the online gear calculators.
But you need to decide on a tire size!!!! That can change alot the 4.7 could be a problem with a low redlining LS with boost.
Old Apr 27, 2008 | 04:05 PM
ucc crx's Avatar
im running 205/50/15 falkan rt-615. 2nd gear would to at 49 mph with the 4.7 do you think thats to low
Old Apr 28, 2008 | 09:52 AM
vbspec's Avatar
Yes 49 MPH is a little low when we were running a STS 91 Civic, and with our 88 CRX Si in STS2 trim whe would pop off the revlimiter every now and then... which was higher than 49MPH. Plus in SM you may want to run R-compound at some point too. There is no right answer to this just things to think about..
Best of luck!
Old Apr 28, 2008 | 10:21 AM
ucc crx's Avatar
next season i am going to getting R comps i just got theres tires last year and they still have good tread on them so i wanted to finish these first. i think im going to shout for something with a 4.4 fd that would put me at around 55.
Old Apr 28, 2008 | 10:51 AM
tronic's Avatar
I would shoot for gearing that puts the top of 2nd gear at about 65mph, any less and you'll be bouncing off the rev limit or wishing you had time to shift to 3rd for a split second. You have to consider the combination of transmission gears, final drive, your rev limit, and tire diameter. The Fatboy calculator mentioned above is your friend.
Old Apr 28, 2008 | 03:37 PM
ucc crx's Avatar
i think im guna try and do a b16 with a quaife or kaaz lsd and ls or gsr 2nd gear. what do you guys think
kings**t
Jun 16, 2008 03:00 PM
squirts2hondas
Nov 8, 2007 05:11 PM
BluFire
Jun 9, 2003 12:14 PM
lshobo
Sep 21, 2002 01:36 PM
