wondering if anyone can help with ecu conversion stuff, like pgmfi used to have
Old Apr 26, 2008 | 08:23 AM
Cimburke23's Avatar
Default wondering if anyone can help with ecu conversion stuff, like pgmfi used to have
anyone have another site that has all of the stuff they used to? like how to do 1-wire to 4-wire o2 conversion, vtec conversion, and all that? thanks in advance
Old Apr 26, 2008 | 02:32 PM
GhostAccord's Avatar
Default Re: wondering if anyone can help with ecu conversion stuff, like pgmfi used to have (Cimburke23)
Is this what your looking for?
Wires on 4 wire O2:
WHITE: Signal Wire
GREEN: Signal Ground
2 BLACK: Both black wires are the heater circuit wires.
This will work for most obd1 ecu's with 4-wire controls
Run O2 Sensor signal white (+) To D14
Run O2 Sensor signal green (-) to D22 (or any good Ground)
Run O2 Sensor Heater Circuit Control black (-) to A6
Run O2 Sensor Heater Power black (+) to (A25) or any good switched +12VDC source.
Old Apr 26, 2008 | 05:46 PM
Cimburke23's Avatar
Default Re: wondering if anyone can help with ecu conversion stuff, like pgmfi used to have (GhostAccord)
no, im talking about the capacitors and resistors writeup on hardware conversions
Old Apr 26, 2008 | 06:01 PM
Ah OK..... I think what your looking for is the PGMFI Library. I think this has a lot of what used to be on the site.
http://www.getglitched.com/pgm....html
Old Apr 28, 2008 | 12:46 PM
Cimburke23's Avatar
thanks a lot
sh!ft
11
Sep 14, 2010 11:56 AM
Iron_Forrix
Jan 11, 2007 06:57 PM
Cm91h22a
Dec 15, 2002 08:51 AM
