2nd Opinion
Old Apr 25, 2008 | 06:53 PM
RinTin's Avatar
Default 2nd Opinion
my 4dr eg mini swap sometimes has a hard time starting. i turn the key and nothing happens other than a oil,battery, and vtec light turning on. no noise going off or anything. my starter doesnt go off either. At other times it start up just fine or i turn the key and the lights i mention turns on and then suddently it starts. so im thinking it is either bad grounding or the starter, but im not sure. i know for sure it has to be electrical. what do you guys think?
Old Apr 25, 2008 | 06:57 PM
slacks's Avatar
Default Re: 2nd Opinion (RinTin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RinTin &raquo;</TD></TR><TR><TD CLASS="quote"> so im thinking it is either bad grounding or the starter</TD></TR></TABLE>
you can always look at the transmission ground cable to see if it's torn of worn out
the thing you can't see is your starter solenoid.. could be bad.
find a cheap starter or borrow one from a friend and see if that works.
either way i would check the ground cable anyway
Old Apr 25, 2008 | 07:02 PM
RinTin's Avatar
Default Re: 2nd Opinion (slacks)
ill take a look around when i get a chance to. im at work right now so i cant do much right now.
Old Apr 25, 2008 | 07:59 PM
Former User's Avatar
Also check that the battery connectors and terminals, as well as starter connectors, are tight and not corroded.
Old Apr 26, 2008 | 01:02 PM
RinTin's Avatar
Default Re: 2nd Opinion (RonJ@HT)
ok i will. thanks for your opinion guys
Old Apr 26, 2008 | 09:22 PM
RinTin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slacks &raquo;</TD></TR><TR><TD CLASS="quote">
I found out my tranny ground was not completly connected. i must have forgot to tighten it when i installed my new tranny. it hasnt failed to start on me so far since i tighten the ground so problem is fixed for now
Old Apr 26, 2008 | 09:28 PM
Nice call by slacks!
azandford
Apr 29, 2010 06:03 AM
Drian
Acura TL, RL & ZDX
Oct 11, 2005 12:32 PM
endlesswinterco
May 16, 2005 08:59 PM
CrX-To-Tha-Max-v2.0
Mar 1, 2005 09:44 PM
CeoStatus0
Jul 18, 2004 02:04 AM
