Transmission Question
Old Apr 25, 2008 | 02:49 PM
91 Civic B16's Avatar
Default Transmission Question
I just want to be sure on this. I got my b16 swap in my civic a few years ago now. I am very sure I got a JDM S1 transmission with it. Can this trans be rebuilt? I hear about JDM synchros and such that make it so that not every rebuilder can rebuild it. Would it be better for me to find a USDM S1 that can be rebuilt, or is there someone in the So CA area that rebuilds JDM transmissions? Thanks in advance for the info. Kudos to this board for always being help!!
Old Apr 25, 2008 | 03:50 PM
zCivic's Avatar
Default Re: Transmission Question (91 Civic B16)
The JDM Synchro is a bunch of BS. Just get synchros and hubs from a 90-91 Integra., Acura usually doesn't stock them so you may have to wait on them but you can still get them. If you go with a USDM S1 (LS trans) your going to lengthen out your gears a ton, seeing you have a B16 rebuild yours. Anyone who can rebuild a trans should be able to do it.
Old Apr 25, 2008 | 04:52 PM
eda6's Avatar
Default Re: Transmission Question (zCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zCivic &raquo;</TD></TR><TR><TD CLASS="quote">The JDM Synchro is a bunch of BS. Just get synchros and hubs from a 90-91 Integra. </TD></TR></TABLE>
I've opened up both jdm and usdm s1 transmissions.
The usdm gear cones on 3rd and 4th are larger than the jdm b16 3rd and 4th gear.
usdm 90-91 teg 3rd/4th synchro set WILL NOT FIT in a 90-91 jdm b16 tranny.
Old Apr 25, 2008 | 06:08 PM
Default Re: Transmission Question (eda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">
Please clarify what that means. No I cannot have it rebuilt? I can understand the idea of parts not fitting, but I am looking for a solution here. Thanks again for the feedback!!
Old Apr 26, 2008 | 10:53 AM
zCivic's Avatar
Well thats odd that they don't fit especially the S1, I just rebuilt mine last season using 90-91 Hubs and synchros from Honda without any problems (yes it is a JDM B16 I have verified the teeth count on every gear). Also when I purchased just synchros from gearspeed they said to use 90-91 Integra parts along with Mike L. So not sure what why was larger unless you had a 92+ that you were comparing to.
Old May 1, 2008 | 11:59 PM
I appreciate the info. Thank you.
Old May 2, 2008 | 10:17 AM
mike@OSTdyno.com's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zCivic &raquo;</TD></TR><TR><TD CLASS="quote">The JDM Synchro is a bunch of BS. Just get synchros and hubs from a 90-91 Integra., Acura usually doesn't stock them so you may have to wait on them but you can still get them. If you go with a USDM S1 (LS trans) your going to lengthen out your gears a ton, seeing you have a B16 rebuild yours. Anyone who can rebuild a trans should be able to do it. </TD></TR></TABLE>
I agree!
antballs420
Jan 8, 2014 09:46 PM
93hatch
Honda CR-V & Element
11
Jan 17, 2013 03:41 AM
anothersickhatch
Aug 14, 2004 06:58 AM
BigIslandBoi
Mar 23, 2004 06:08 PM
ironchef25
21
Nov 20, 2003 12:23 AM
