ZC Dohc dizzy interchangeable with d16a6??
Having trouble with starting after the car has been sitting for 6 to seven hours and car idles high at times ,and its running very rich. anyways i have code nine along with many other CELs. But want to know if the dizzy i have on this ZC will fit up to the d16a6 . thanks ,, and how to you post pics with the msg thanks
no, the d16a6 diz is not the same as the zc diz. i'm guessing you have a dual cam black top zc? then it is the same part as the 88-89 integra... part no. TD03U. if you have a zc, you should really become a member at the zcr
90wagon4wd
Jan 9, 2004 06:01 AM
