IACV: code 14 w/ new p13, but not w/ p28 + uberdata???
Old Apr 25, 2008 | 01:20 PM
DarkBB4's Avatar
Default IACV: code 14 w/ new p13, but not w/ p28 + uberdata???
I just installed a JDM obd1 p13, and now I have a cel for 14 (iacv) and the car is running like garbage. Low idle, jerking, the works.... When i swap back to my p28, it runs fine!! I opened up the ECU, but i didn't see any burnt components or anything.
Ive never had an issue w/ my iacv, and the electirical connections are fine....
WTF?!
Old Apr 25, 2008 | 02:17 PM
Acidcrakker's Avatar
Default Re: IACV: code 14 w/ new p13, but not w/ p28 + uberdata??? (DarkBB4)
On your uberdata program, who tuned it?
YOu can tune an ECU to function without an IAVC that might be your issue. Your IAVC might actually never have worked right.
Also why are you switching ECU's?
Old Apr 25, 2008 | 05:10 PM
DarkBB4's Avatar
Default Re: IACV: code 14 w/ new p13, but not w/ p28 + uberdata??? (Acidcrakker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">On your uberdata program, who tuned it?
Also why are you switching ECU's?</TD></TR></TABLE>
its a basemap from j-k-tuning.com, im not sure if its disabled or not.... I'm switching to the P13 to spray nitrous w/ the zex management system. I dont want to run on a basemap, and i cant afford 300$ for a tune at the moment
Old Apr 26, 2008 | 11:11 AM
DarkBB4's Avatar
is that the only possiblity?
should i try cleaning it?
Old Apr 26, 2008 | 12:19 PM
mgags7's Avatar
I would just assume that the p13 is bad here.
See if you can find another ecu to try from a friend or something.
Old Apr 26, 2008 | 01:17 PM
98vtec's Avatar
moderator emeritus
test the IACV output at the ecu and make sure its getting the correct voltage.
Old May 8, 2008 | 05:46 PM
DarkBB4's Avatar
Default Re: IACV: code 14 w/ new p13, but not w/ p28 + uberdata??? (98vtec)
what is the correct voltage?
i just swapped iacv's and im still getting a code
Old May 8, 2008 | 06:04 PM
98vtec's Avatar
moderator emeritus
with the ignition on, the yellow/black wire (ground) should get battery voltage.
If yes, test the voltage at the ecu and body ground - http://technet.ff-squad.com/wiring.obd1.htm - connector A, pin 9. Should get battery voltage
If yes, jumper the IACV pin (9) with the A23. The iacv should click. If it doesnt click try another ecu.
ev13lf
Jan 4, 2007 06:12 PM
SkoundrelUSA
29
Nov 10, 2005 06:28 PM
95accordh22a
Apr 8, 2005 08:03 PM
98HB
May 10, 2004 07:26 PM
dsm this
Apr 3, 2004 09:18 AM
