another car won't start thread....
Old Apr 25, 2008 | 12:58 PM
chero112's Avatar
Default another car won't start thread....
I just drop a 00b18c1 in my 93 del sol. after I put all the plugs in and ecu(p72)
I tried to start the car. It crank for a while and didn't turn over, so I check to make sure I was getting fuel. After I fixed that problem I tried to start the car again and nothing... The fan turns on that's it.... no crank no nothing.... I check all the fues I double check all the grounds. don't know what else to do......
honda-guys please help me out........
Old Apr 26, 2008 | 06:54 PM
chero112's Avatar
Default Re: another car won't start thread.... (chero112)
thanx guys for all the help....
Old Apr 26, 2008 | 07:15 PM
Former User's Avatar
You may be having a problem with your starter. Try wiring it directly to the battery to see if it will crank the engine. If not, replace it.
Old Apr 26, 2008 | 11:59 PM
obuhmyuh's Avatar
Default Re: another car won't start thread.... (RonJ@HT)
check and double check and triple check your wiring. after i made sure all of my plugs are in good shape and in the right place i would move on to fuses, then check my grounds, and end with checking my ecu. Did the ecu work before you used it in the car? If there is a blown ECU fuse you might have gotten the ecu too.
your battery sounds like its fine. it could also be ur dizzy.
Old Apr 27, 2008 | 08:05 PM
chero112's Avatar
Default Re: another car won't start thread.... (obuhmyuh)
it was a blown ecu fuse thanx
Old Apr 27, 2008 | 11:38 PM
obuhmyuh's Avatar
haha yesssss!!!!!! Good job
Old Apr 28, 2008 | 11:14 AM
chero112's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by obuhmyuh &raquo;</TD></TR><TR><TD CLASS="quote">haha yesssss!!!!!! Good job </TD></TR></TABLE>
thanx for the help.....you get a form me
97_delsol_Vtec
May 4, 2007 04:28 PM
hurraquio
Feb 4, 2006 07:34 PM
Audio28
Jul 3, 2003 05:33 PM
lude97dude
Jan 21, 2003 08:53 PM
DCtwoR
Jun 20, 2002 07:10 PM
