ok two quick questions.......
Old Apr 25, 2008 | 11:22 AM
pat91hb's Avatar
Default ok two quick questions.......
1 .im blowing oil....really bad to where it seems like i put a quart of oil in with every stop at the gas pump....im guessing rings/valves??? theres oil you can wipe offa my back bumper it aint leaking
2. theres a hole the size of a dime in my lower portion of the exhaust manifold....im getting headers soon but wanna make sure this isnt going to cause internal damage (as i know open headers does)
Old Apr 25, 2008 | 06:55 PM
pat91hb's Avatar
Default Re: ok two quick questions....... (pat91hb)
Old Apr 25, 2008 | 07:15 PM
00Red_SiR's Avatar
All Motor Mentor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pat91hb &raquo;</TD></TR><TR><TD CLASS="quote">1 .im blowing oil....really bad to where it seems like i put a quart of oil in with every stop at the gas pump....im guessing rings/valves??? theres oil you can wipe offa my back bumper it aint leaking
Have a leak down test performed at a decent garage to see how healthy your motor is....sounds like it needs a rebuild.
This is completely wrong. Where did you come up with that?
Old Apr 25, 2008 | 07:33 PM
hamst3r3x's Avatar
Default Re: ok two quick questions....... (00Red_SiR)
open header rules, im like that all the time never had a problem only the noise...lol
Old Apr 25, 2008 | 09:24 PM
JakeSpec's Avatar
oil rings, Cracked Guide(s) bad valve seals too? Numerous problems
Old Apr 26, 2008 | 05:21 AM
pat91hb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR &raquo;</TD></TR><TR><TD CLASS="quote">
This is completely wrong. Where did you come up with that?</TD></TR></TABLE>
well my buddy whose got a 89 mustang ran open headers for a while then started bending valves.... he took it to a performance shop and the first thing they told him was to get a damn exhaust on his car because the open headers (somehow with the pressure or someting with his headers....) was destroying the valvetrain
Old Apr 26, 2008 | 05:38 AM
pat91hb's Avatar
When you run with open header for a long period of time you have a chance of bending valves due to cold air going through the header to quickly.i just reserched that online...i guess thats what the risk is... (he hadd an all out racer it could be different)
Old Apr 26, 2008 | 01:30 PM
00Red_SiR's Avatar
All Motor Mentor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pat91hb &raquo;</TD></TR><TR><TD CLASS="quote">When you run with open header for a long period of time you have a chance of bending valves due to cold air going through the header to quickly.i just reserched that online...i guess thats what the risk is... (he hadd an all out racer it could be different)</TD></TR></TABLE>
If the hot air, compression, explosions and high RPM aren't enough to bend valves, do you really think "cool/cold" air will? If there was any logic to this, everyone who sprayed nitrous would have bent valves.
Cold air does not and cannot physically bend a valve. Stay far away from that performance shop that gave that explaination. If he bent valves, it would have more to do with possibly floating them numerous times or more than likely piston to valve contact.
Old Apr 26, 2008 | 02:12 PM
pat91hb's Avatar
Cold air does not and cannot physically bend a valve. Stay far away from that performance shop that gave that explaination. If he bent valves, it would have more to do with possibly floating them numerous times or more than likely piston to valve contact.</TD></TR></TABLE> ok yea that makes sense to me....idk theres a couple people on here that say to stay away from open headers when i searched "open headers"....but i see your logic and im not worried about it since im gettin some headers soon.
Old Apr 27, 2008 | 07:05 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (dx2sicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dx2sicrx &raquo;</TD></TR><TR><TD CLASS="quote">without the back pressure you need you can float valves</TD></TR></TABLE>
Incorrect. Valve springs control valve float, back pressure has nothing to do with it.
Old Apr 27, 2008 | 08:00 AM
mar778c's Avatar
Community Builder
Community Influencer
Lol, this gets funnier all the time.
Old Apr 27, 2008 | 10:51 AM
AccordSleeperZzZ's Avatar
Default Re: (mar778c)
wow. thats funny as hell. but. wow.
misinformation FTL
Old Apr 27, 2008 | 11:07 AM
Chris Tune's Avatar
BACKPRESSURE FTW
Old Apr 27, 2008 | 11:46 AM
imzjustplayin's Avatar
Default Re: (Chris Tune)
So is that why performance enthusiasts go for the smallest diameter exhausts. And people with the fart can exhausts are just doing it for fuel economy and not power?
Old Apr 27, 2008 | 11:47 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (imzjustplayin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris Tune &raquo;</TD></TR><TR><TD CLASS="quote">
BACKPRESSURE FTW </TD></TR></TABLE> = sarcasm.
Old Apr 27, 2008 | 12:06 PM
Combustion Contraption's Avatar
Simply stunning.
Old Apr 27, 2008 | 12:16 PM
98vtec's Avatar
moderator emeritus
i hope you are joking.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imzjustplayin &raquo;</TD></TR><TR><TD CLASS="quote">So is that why performance enthusiasts go for the smallest diameter exhausts. And people with the fart can exhausts are just doing it for fuel economy and not power? </TD></TR></TABLE>
KyoCivic98
17
Aug 21, 2009 04:21 AM
Frstyl838
Oct 20, 2007 08:05 AM
SD99GSR
Jul 24, 2007 03:36 PM
kihun_cha
Jan 2, 2006 07:45 AM
CivicBoi
May 27, 2002 11:59 AM
