EGR Vacuum Control Valve and Solenoid H22
Old Apr 25, 2008 | 07:49 AM
wadsworth's Avatar
Default EGR Vacuum Control Valve and Solenoid H22
My H22A doesn't seem to have come with either of these two parts. I can't hook my EGR valve directly to vacuum or it will just stay open all the time.
Can someone snap a pic of what the vacuum routing looks like coming off the EGR, and where the VCV (vacuum control valve) and control solenoid is mounted?
Old Apr 25, 2008 | 10:08 AM
Hawkze_2.3's Avatar
Default Re: EGR Vacuum Control Valve and Solenoid H22 (wadsworth)
The vacuum line coming from the EGR valve is supposed to go directly to a vacuum source. The electrical connector on top is what makes it open and close.
Old May 2, 2008 | 03:05 PM
wadsworth's Avatar
Default Re: EGR Vacuum Control Valve and Solenoid H22 (Hawkze_2.3)
Not on all of the us preludes that I've seen..
Are the JDM ones different?
Old May 2, 2008 | 05:07 PM
lude98SH's Avatar
there should always be vacumm to the solenoid but not to the valve. The valve should only open while the engine is hot and at steady cruise. So your answer is most likely no they are not different, I cant see how they would be. The solenoid itself may be different or mounted differently but the egr valve can never see vacuum all the time (always open).
Old May 2, 2008 | 07:20 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wadsworth &raquo;</TD></TR><TR><TD CLASS="quote">Not on all of the us preludes that I've seen..
Are the JDM ones different?</TD></TR></TABLE>
Oh, you're right, I have had mine hooked up different for a long time now...
Sorry about that, do these help?
5th gen:
4th gen:
Old May 2, 2008 | 11:51 PM
lude98SH's Avatar
From what I see number 5 has to be linked somehow to 17 or 18 so that there is a vacumm source there. But i dont see anything in that diagram. Yes the vacumm routing is different but the concept still has to be the same.
Old May 3, 2008 | 09:14 AM
Hawkze_2.3's Avatar
Default Re: EGR Vacuum Control Valve and Solenoid H22 (lude98SH)
Oh, and the control units:
5th gen:
4th gen:
Old May 3, 2008 | 02:06 PM
lude98SH's Avatar
ok that makes alot more sense. Same idea as the 5th gen just routed alittle differently
Old May 12, 2008 | 09:24 AM
wadsworth's Avatar
Yes, thanks for the replies.
I went to a junk yard and checked out how these things hook up.
My prob is my harness doesn't have a connection for the EGR solenoid.
Ry-wire is working on it.
RoscoeT
Jul 25, 2015 09:12 PM
hotair
Nov 24, 2013 01:34 PM
wadsworth
Apr 28, 2008 09:20 AM
cidery
Aug 10, 2006 07:06 AM
