lsvtec ignition timing question.....
Old Apr 24, 2008 | 11:01 PM
jdmb16ef8's Avatar
Default lsvtec ignition timing question.....
hey im just curious what should the stock lsvtec ignition timing set at....???? and will advancing it at all make a difference....??? any ideas and info will help thanx
Old Apr 25, 2008 | 05:16 AM
D-Rob's Avatar
Default Re: lsvtec ignition timing question..... (jdmb16ef8)
Set your base timing to 16* BTDC.
Make sure the service connector is jumped, and the engine is warmed up.
If you want to add more ignition timing, really look into something like CROME, Uberdata, NepTune, eCtune, etc... and add ignition timing values through the ECU.
A change at the distributor is a global adjustment.
- Derek
Old Apr 25, 2008 | 05:26 AM
b19coupe's Avatar
Tuning the ignition timing curve, along with the air fuel, is an integral part of a complete engine package. To do that properly, you need engine management-Crome, Hondata, AEM. 16-18 degrees BTDC at idle is a good starting point.
Old Apr 25, 2008 | 03:27 PM
jdmb16ef8's Avatar
can someone please tell me where this connector is that im supposed to jump to adjust the ignition timing.... i adjusted the dizzy without the connector being jumped and i did see a nice change in low end power when i advanced the timing but would it be possible to advance it too much on a stock lsv (block is bone stock) and cause it to detonate??? the car does seem to be pulling better tho and it idles at a steady 700
Old Apr 26, 2008 | 07:45 AM
jdmb16ef8's Avatar
Old May 1, 2008 | 02:05 PM
atech34's Avatar
if your in an eg civic i believe the connector is located in the passengers footwell near the ecu not sure on the wire colors though i believe you cant set your dizzy timeing to 16-28 btdc though without it jumped so you you should look into a wiring diagram and find it youll know you have it right when you start the car and the check engine light blinks a few times that meens its in timing mode
Old May 2, 2008 | 11:05 AM
atech34's Avatar
Default Re: lsvtec ignition timing question..... (atech34)
sorry that was 16-18 btdc not 28
Old May 2, 2008 | 03:24 PM
jdmb16ef8's Avatar
ok so i still cant find this jumper for the ecu to set ignition timing im running obd1 step up harness in an 88-89 crx where is this jumper pls someone tell me where it is!!!
Old May 3, 2008 | 09:10 AM
jdmb16ef8's Avatar
i need to know where this jumper is so i can set my timing does 88-89 crx have this jumper to jump the ecu.........
Old May 3, 2008 | 10:54 PM
jdmb16ef8's Avatar
i need to know where this ecu connector is asap on a crx si pls help
Old May 4, 2008 | 04:47 AM
ef92b's Avatar
just put a jumper wire on pins D4(brown) and D22(green/white).
beocop
Dec 15, 2016 09:05 AM
I CRX I
Engine Management and Tuning
Jan 30, 2009 07:11 AM
mortificationrock
Jul 10, 2007 04:26 PM
wytechoppin
Feb 28, 2007 05:52 AM
RTW DC2R
Mar 9, 2004 09:09 AM
