2 step???????????
Looking into running my jdm itr motor with a chipped p28, eternals are stock is a chipped ecu recommended? also I was told not to put a 2step in it is there a reason 4 that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hamst3r3x »</TD></TR><TR><TD CLASS="quote">i love my 2 step, i guess it just depends on if your running with street tires or slicks</TD></TR></TABLE>
slicks
slicks
well i have mine at 7800, i don't know how your going to install the 2step but if you can adjust it your self start high u would want to spin a little because if you bog u will have a greater chance in breaking something. start high play with the tire pressure then adjust the 2step from there to see where u get your best 60fts.....hope that helps but as far as 2step goes u cant go wrong its 1 less thing u have to worry about at the line.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hamst3r3x »</TD></TR><TR><TD CLASS="quote">well i have mine at 7800, i don't know how your going to install the 2step but if you can adjust it your self start high u would want to spin a little because if you bog u will have a greater chance in breaking something. start high play with the tire pressure then adjust the 2step from there to see where u get your best 60fts.....hope that helps but as far as 2step goes u cant go wrong its 1 less thing u have to worry about at the line.</TD></TR></TABLE>
Tx alot
Tx alot
