thinner or thicker head gasket?
Old Apr 24, 2008 | 07:16 PM
mrbutters's Avatar
Default thinner or thicker head gasket?
im not sure if going with either a thinner or a thicker head gasket is better. just looking for some advice
Old Apr 24, 2008 | 07:21 PM
Audiojb's Avatar
thinner will increase compression
Thicker will decrease (better for boost)
All depends what your plans for the motor are.
Old Apr 24, 2008 | 07:24 PM
mrbutters's Avatar
Default Re: (Audiojb)
k thanks for your help. im planning on going all motor
Old Apr 24, 2008 | 07:27 PM
Audiojb's Avatar
ya I used a .030(thinnest in stock i think) cosmetic from nipponpower for my all motor build
Old Apr 24, 2008 | 07:32 PM
mrbutters's Avatar
im thinkin about going with buddy club spec 4 cams with buddy clubs valvesprings and retainers but im not sure if it would still be street driveable.
Old Apr 24, 2008 | 07:33 PM
mrbutters's Avatar
Default Re: (mrbutters)
i mean with those aggressive cams.
Audiojb's Avatar
eh Im not sure. Im running blox hsl's (equivalent to skunk2 stage 3s) with blox titanium valvetrain for my build.
Old Apr 24, 2008 | 07:36 PM
Racebrewer's Avatar
Hi,
Its really not worth pulling the head just to use a slightly thinner headgasket. You won't gain that much in compression.
If you pull the head you should get it skimmed a few thousandths to make sure that it will seal properly. If you are going to skim it, you might want to take off enough to make a difference in compression.
The problem with that is twofold. It will retard your valve timing, so you'll need adjustable cam gears. It will also limit your piston to valve clearance in case you wanted to go with some really zippy cams.
However, if you go with really zippy cams, due to the overlap you will lose effective compression. In that case, you may need high compression pistons. On and on it goes.
Really decide what you want before you go there.
John
Modified by Racebrewer at 4:41 AM 4/25/2008
Old Apr 24, 2008 | 07:41 PM
mrbutters's Avatar
Default Re: (Racebrewer)
thanks. what im planning on doing is to do a fully built motor and do all the valvetrain and pistons etc. then. im not pulling off the head just to put a head gasket on.
Old Apr 26, 2008 | 12:12 PM
Racebrewer's Avatar
Hi,
Good thinking. People will put in BIG cams and go slower because they lose compression due to the valve overlap (both valves open at once).
If you go with really hot cams you will need larger injectors and a new ECU or piggyback. Nice thing about VTEC is that you can often find cams where the lower rpm lobes are close to stock ITR so it retains very good driveability.
BTW, If you shift your powerband upwards too much, you will have to change your gearing to get it to work.
There are a lot of things to consider. Remember, you are working with a system. All of the various things such as flow, lift, compression, etc, etc, all interact and not to the best.
Remember, also, to keep in mind what quality of gas is available and your state's inspection laws. And, of course, $$$$$$$$$$$.
John
Old Apr 26, 2008 | 01:25 PM
mrbutters's Avatar
yeah. thanks alot for your advice. but is there any way to tell when buying cams that it well mess with the powerband too much? and what duration would you reccomend on cams for itr's. thanks for your help.
Old Apr 27, 2008 | 07:40 AM
bleke's Avatar
if your interested I have a buddy club full head package for sale, I have spec 4 Camshafts, b18c5 Cam gears, valve, salve springs and retainers all made by buddy club, there brand new in box never installed. Ill be letting them go for $1200 CDN if your interested contact me
Old Apr 27, 2008 | 07:04 PM
Racebrewer's Avatar
Hi,
Cam selection depends upon what you want to do with the car and how much money you have/how extreme you want to go. A car is a system. All the factors need to work together.
In a naturally asperated motor as the cams get 'hotter' there is a physical loss of compression due to overlap. To compensate you have to increase static compression. This will make the cams work. The cams also raise and narrow the powerband so you have to rev higher and change the gearing and shift more often.
In the late 1960's, Honda built some incedibly powerful Formula One engines. Their powerband was incrediby peaky and to make the powerband useful they had to have 17 speed gearboxes. The driver had to shift thousands of times per race.
Most people look at what is easiest to do first and cams are one of those things. Cams should be the last thing you do, if you do things in steps as you can afford them. If you can do it legally, the very first thing you should actually look at is a programable ECU to control what the motor is doing along with an EGT and a wideband AFR to monitor it. There are some very good ECU's out there, but they aren't legal in many states (I live in one, NY).
John
Old Apr 28, 2008 | 09:39 AM
CW-ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racebrewer &raquo;</TD></TR><TR><TD CLASS="quote">Hi,
In a naturally asperated motor as the cams get 'hotter' there is a physical loss of compression due to overlap. To compensate you have to increase static compression. This will make the cams work. The cams also raise and narrow the powerband so you have to rev higher and change the gearing and shift more often......John</TD></TR></TABLE>Hi John, when you said "increase static compression", what do you meant by that? Can you give us an example? Thanks.
-Chris-
Old Apr 28, 2008 | 12:32 PM
mrbutters's Avatar
k thanks a lot john. you have really given some good advice. thank you.
Old Apr 28, 2008 | 12:34 PM
mrbutters's Avatar
could you also suggest a programmable ecu to me. thank you
Old Apr 28, 2008 | 12:43 PM
mrbutters's Avatar
would you suggest a hondata? im sorry im a complete n00b bu what is an egt? thanks for your help
Old Apr 28, 2008 | 12:46 PM
mrbutters's Avatar
never mind found out what an egt was. sorry
preluking
Oct 19, 2008 04:36 PM
all-mtr-teg
15
Nov 30, 2006 08:43 PM
tunedek
Jul 20, 2004 05:15 PM
Nikolai
Jul 17, 2002 09:39 AM
Unsung
May 25, 2002 12:19 PM
