using a small motorola 3 bar map sensor, what specs to use in crome
Old Apr 24, 2008 | 06:19 PM
darrinbrewer's Avatar
Default using a small motorola 3 bar map sensor, what specs to use in crome
i have crome 1.2 and a 3 bar motorola isnt in the list, my car runs the 2.5 fine, bu ti'm getting ready to put this 3 bar super tiny one in(fits on your pinky fingernail, real small.
what specs do i run this at?
crome has a gm 3 bar, and gm 3 bar test, both with different settings.
thanks,darrin
Old Apr 24, 2008 | 09:15 PM
mtber's Avatar
Default Re: using a small motorola 3 bar map sensor, what specs to use in crome (darrinbrewer)
The xenocron 3 bar settings should work fine.
Don't ask me why it's labeled this when xenocron doesn't produce the sensor.
Old Apr 25, 2008 | 04:11 AM
Default Re: using a small motorola 3 bar map sensor, what specs to use in crome (mtber)
were's the xenocron settings your reffering to? is that listed in a later version of crome to choose from? i searched his site, but didnt find a tech article or anything.
Modified by darrinbrewer at 2:04 PM 4/25/2008
Old Apr 25, 2008 | 05:48 PM
nowtype's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">The xenocron 3 bar settings should work fine.
Don't ask me why it's labeled this when xenocron doesn't produce the sensor.</TD></TR></TABLE>
A better question to ask is, why have two formulas when the GM and Motorolla 3 bar sensors use the EXACT same formula.
Old Apr 25, 2008 | 07:31 PM
KENetics1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darrinbrewer &raquo;</TD></TR><TR><TD CLASS="quote">were's the xenocron settings your reffering to? is that listed in a later version of crome to choose from? i searched his site, but didnt find a tech article or anything.</TD></TR></TABLE>
when enable boosttools on your map it will ask you what map sensor you are using and you select the 3bar map sensor in the dropdown box.
Old Apr 25, 2008 | 08:35 PM
mtber's Avatar
Download the latest version of crome. Click plugins/advanced boost tools & your good to go.
AJxr
Engine Management and Tuning
Oct 2, 2008 10:12 AM
RACEPAK
Jul 23, 2006 02:32 PM
thermal
Apr 20, 2005 11:40 AM
Hybrid
Jun 27, 2003 05:15 PM
0-60n4
May 22, 2002 07:39 AM
