92 Accord- Dash Board Removal
Back to the dash removal though...i bought my 92 accord ex and it cacme with aftermarket indiglo gauges. They will sometimes come on and work for a bit and then shutoff or not come on at all. Is there a diagram to show how to remove dash so i can get to the instrument cluster and trace the wiring for the gauges? Thanks in advance...
you dont have to remove the dase to get to the cluster all you have to do is take of the bezal peaice that goes around the cluster and the radio there are 2 screws right above the cluster and when you pop out all the switches you will find 2 more hidden screws one right behind the dimmer switch and one right behinde the change holder and then you should be able to take the off.
paulff3
Sep 4, 2008 05:46 AM
karmannghia
Nov 7, 2001 07:51 AM
