function form type 2 sqeaky springs?
well i put me in a month ago lowered them down all the way, i made even lower by touching the preload, put the tires bak on dropped the car off the jacks, decided it was to low raised it bak up by the springs, now im hearing sqeaking from the springs? could it be because of wut i did? or is it still to low and i have to raise it back up by the lower perch? will exteneded top hats work/if they have top hats that fit
It's probably your hatch creaking like mine does. My friend, who I got the coilovers from, had the same creaking. It's because the suspension won't take up the slack when the chassis is on an uneven surface. Try to unscrew the hatch adjusters a little, to where you have to slam it down to get it to close.
ZCcivicBOI
Jun 18, 2005 02:23 AM
ted
Suspension & Brakes
Mar 21, 2005 07:44 PM
