Best Camshaft for my setup!
i am currently building my motor consisting of
headgames port and polished cylinder head
ferrea valves
super tech valve springs
super tech retainers
85mm 12:1 cp pistons
jg rods
gsr crank
what cams do you guys reccommend? im kind a new to b-series since i just recently sold my stroke 1.8 turbo d-series motor. Im planning to buy a set of itb also for my setup after i get the motor put all together. i want something that idles fine and gives good midrange/top end power
ferrea valves
jg rods
gsr crank
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg »</TD></TR><TR><TD CLASS="quote">pro 2, m22xx, m25's, bc5's.
fixed (for his motor)
Modified by 00Red_SiR at 12:01 AM 4/25/2008
</TD></TR></TABLE>fixed (for his motor)
pro 2's should beat the bc4's by quite a bit. BC 5's would be similar to the pro 2's. M22xx's would work pretty nice in that setup and be fairly easy to tune.
M24xx or Pro2. What is the intake/header combo and what are you tuning with? Who's doing the tuning? I also wouldn't rule out Pro3/M25 either....degree wheel is your friend though.
All of the cams mentioned in my post are extremely streetable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR »</TD></TR><TR><TD CLASS="quote">
Modified by 00Red_SiR at 12:01 AM 4/25/2008</TD></TR></TABLE>
Thanks, I overlooked the 85mm bore
wfocrx
27
Sep 7, 2015 08:53 AM
slowteg550
Apr 16, 2006 03:55 PM
