brake setup?
Stock brakes are more than adequate. Just get a set of good pads. Hawk, Portfield or Axxis Ultimate.
If you are trying to intimidate people with the quote "die theifs" under your post count, you may want to spell it correctly. Its "thiefs" or use correct english with "die thieves".
[Modified by StageOne, 4:00 PM 7/12/2002]
Stock calipers
Stoptech front rotors
Stock rear rotors
RM Racing front pads
Endless CC-X rear pads
Motul RBF 600 fluid
If I weren't taking it on the track, then stock everything would be just fine. Easiest way to tell is if you've ever boiled your brakes or heated them to the point of severe fade. If not, just leave 'em stock.
sp00led
23
Aug 4, 2005 04:25 PM
Yellow Dragon
Jun 28, 2001 10:12 AM
shi - who'll finally find out how the StopTech big brakes work on the track this weekend
