Looking at building up an engine.
Old Apr 24, 2008 | 01:12 PM
Nickboxer7's Avatar
Default Looking at building up an engine.
I'm just doing some initial research because I plan on building up a project car in a couple years. I was thinking about just going with a B series engine, but possibly a nice D series.
What all needs to be changed to build up an engine? I would like to be able to put a turbo on it if I want to, but not really planning to at first. I would like an all motor car but not sure the best way to do that. Anybody have any good guides to rebuilding a Honda engine?
Again, just kind of looking for a direction for my upcoming project so I don't get into a mess lol. I would like to take my time and do it the best I can, but I'm not interested in a drag car by any means. I just want something that could be driven happily everyday, or go to a car show hehe.
Old Apr 24, 2008 | 01:30 PM
slvrcvc93's Avatar
Default Re: Looking at building up an engine. (Nickboxer7)
The best advice anyone can give you is Build it once for its purpose if your going to go turbo you need to put low compression pistons if it is going to N/A you would want High Compression Pistons. So build it for its purpose measure twice pay once
Old Apr 24, 2008 | 03:47 PM
Nickboxer7's Avatar
Default Re: Looking at building up an engine. (slvrcvc93)
Alright, but what kind of things should I be replacing. Seriously, I am a noob with engines but would like to make this a learning experience.
Pistons, rods, camshaft? Just not sure what all would be good to change to performance parts.
Old Apr 24, 2008 | 07:13 PM
slvrcvc93's Avatar
Well start with basics and work your way from the bottom up. Get a block have it cleaned and decked or if your gonna have it sleeved. Crank bearings, oil pump and front and rear main seals then your rods you can go with after market rods and pistons which you should get new rod bearings and piston rings. Then with the head a simple port and polish valves, valve springs, retainers and new valve stem seals then cams and cam gears. Also water pump and head bolts depending on what your preferece is after that headers intake manifold throttle body fuel rail fuel injectors. ITS GONNA COST YOU but always build the bottom once you can take the head off alot its quick.
Old Apr 24, 2008 | 07:19 PM
Nickboxer7's Avatar
I realize it's gonna cost me. That's why I'm not jumping into it right now. I gotta have goals and my goal within the next 3 years is to start working on something like this. I want to build up a hatch to seem like a new car The DD hatch just doesn't do itself justice.
Old Apr 25, 2008 | 11:27 AM
slvrcvc93's Avatar
Yessir belive me a simple Car Repair Manuel is a good source of info
nighthawk2318
11
Mar 24, 2017 08:04 AM
viperjng
17
Oct 15, 2015 05:54 AM
alaska street racer
18
Apr 26, 2009 01:54 PM
Siberian Husky
Sep 6, 2005 08:05 AM
